Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-22-2007, 12:55 PM   #1
Rewards Points: 123
Door
Is it usual for a door to have two different colors or finishes on each side?
jerome8283 is offline   Reply With Quote
Old 02-22-2007, 04:51 PM   #2
If it is the entry door of the house... I would say it is very common....
if it is an internal door... it is unusal but don't think it matter... this is totally artistic thing... when match with other surrounds may looks great...
KUIPORNG is offline   Reply With Quote
Old 02-22-2007, 05:58 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are referring to different looking grains of wood on a solid wood panel door...then, the answer is yes...
- Build Well -
Old 02-22-2007, 06:54 PM   #4
Rewards Points: 123
It's two new interior bedroom doors. Both doors face the same hallway and I want the hallway facing doorway to be a cherry stain and the room facing to remain natural wood.
Old 02-22-2007, 07:46 PM   #5
In that case: no is the answer to your original question ... sorry
- Build Well -
Old 02-22-2007, 09:42 PM   #6
remodeling pro
The problem with this is that when the doors are open, which is most of the time, they visible door color is going to be the opposite of the trim color in the bedroom; the cherry doors will be laid against the natural colored base board. I would think not a good idea.
troubleseeker is offline   Reply With Quote
Old 02-24-2007, 02:22 PM   #7
Steve
STEPHENWANGEL's Avatar
Take it from an old paint man...
The typical rule of thumb is that the color of the face of the door goes to the room it's in when it's closed... Period
Steve Wangel
STEPHENWANGEL is offline   Reply With Quote
Old 02-24-2007, 06:23 PM   #8
Rewards Points: 123
Thanks guys. I decided to go with my original plan, one side natural and the other cherry.
Old 03-09-2007, 10:23 AM   #9
Rewards Points: 123
Steve Wangel
The trim on either side should match the room but what about the inside jam of the door?
Old 03-09-2007, 10:46 AM   #10
Steve
Trim Colors
Close the door. what ever shows to the hall, belongs with the hall. The portion of the jamb that you can't see will go to the inside room (if it's an in-swing door). The door edges go to the area that they're seen from when the door is full open.
If you have other questions, please e-mail me.
stephenwangel@msn.com
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 09:53 PM
Walkout Basement Door allworld Building & Construction 1 06-17-2006 01:50 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
