Don't Know Where To Post This.. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 06:26 PM   #1
Don't know where to post this..
Hi guys,
We have a door in the garage that leads to the backyard. There is a small gap between the door and the concrete flooring which lets all these bugs in.
Does anyone know the name of the equipment that I can put in between the door and the floor and still be able to open the door just fine? If it I can pick it up and a Lowe's or Home Depot, that would be great.
Thanks!
M3GAPL3X is offline   Reply With Quote
Old 07-03-2010, 06:33 PM   #2
Rewards Points: 97
You want a door sweep.It is a type of weatherstriping that attaches to the bottom of the door and screws on.You may even be able to get a magnetized one.
scarrylarry
scarrylarry is offline   Reply With Quote
Old 07-03-2010, 06:34 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are you thinking of a threshold?
I can't find any good pics quickly but it is the device that often has a rubber strip that seals a door when it is closed.
here is a pic of one type of threshold:
http://www.wjdennis-rcr.com/Portals/...ld-Alu-Adj.jpg
Old 07-03-2010, 06:34 PM   #4
Thanks a lot!
Old 07-03-2010, 06:36 PM   #5
Yea I believe a door sweep is what I am looking for:
Old 07-03-2010, 07:03 PM   #6
Old School
Willie T's Avatar
Of course they cost a lot more, but there is a "sweep" that doesn't actually sweep. Regular sweeps can sometimes make it difficult to open a door if they drag on the floor during opening.
This other kind has a mechanical trigger (spring) that holds the sweep up higher than the floor while the door is swinging, and as the door shuts against the jamb, it forces the sweep downward, sealing off the bottom of the door.
Shown, in an end view, is one kind that fits into a groove in the bottom of the door. There are external types too. Google "Automatic Door Seals", and you should be in the ballpark.
Willie T
Old 07-03-2010, 08:28 PM   #7
Rewards Points: 97
R.C.R. is the name of the manufacturer I was thinking of. I have used their products with no problems.you would probably find their stuff in HD
scarrylarry
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Is this a load bearing post Kraig Building & Construction 11 04-21-2009 03:27 AM
