Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-12-2012, 04:51 PM   #1
dog getting out under fence! need ideas please
so the back yard is fenced but it is on a slope and the bottm of the fence does not meet flush with the ground and my dog being the curious meathead he is loves to sneak under and get us all in trouble...i dont want to just screw some plywood along the bottom thinking the neighbours wouldnt be thrilled...thinking lattice ? help please
turpin123 is offline   Reply With Quote
Old 02-12-2012, 05:01 PM   #2
May as well but up cardboard.
Lower the fence and use crushed stone againt it or
go buy some Invisable fence or have it installed for you.
Old 02-12-2012, 07:35 PM   #3
Disabled wood vet
titanoman's Avatar
Lattice will just fall apart.
Do like Joe says or tell meathead not to do that anymore.
titanoman is offline   Reply With Quote
Old 02-12-2012, 07:41 PM   #4
Don’t know how much space there is between the bottom of the fence or what type of fence you have. So send a pix, I will be able to then tell you what to do. I have dogs for 45 years, never an escape!
Hardway is offline   Reply With Quote
Old 02-12-2012, 09:23 PM   #5
STAFF
BigJim's Avatar
Electric fence wire 6 inches above the ground 6 inches away from the wood fence. The dog touches it a few times and you can turn it off.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
stickjim (02-24-2012)
Old 02-12-2012, 09:48 PM   #6
NceptioN's Avatar
Best way.
NceptioN is offline   Reply With Quote
Old 02-12-2012, 11:03 PM   #7
I've got a place where my dog can get out from under the deck on our stairs. I had a piece of welded wire fence that I trimmed to fit. As long as it stays in place, my dog never leaves. Every once in a while it comes loose, but it was free and it works.
cibula11 is offline   Reply With Quote
Old 02-12-2012, 11:56 PM   #8
Ironlight's Avatar
I would try just stapling some chickenwire along the bottom and see what happens. Dogs really don't like wire and after poking his nose in it and having it feel weird against his paws he'll probably back off. It's the cheapest easiest solution for the short term.
If that does not work, and electrified wire will definitely "learn him good" and pretty well eliminate the problem permanently by changing his behavior.
Ironlight is offline   Reply With Quote
Old 02-13-2012, 05:06 PM   #9
If you don't like the elect fence idea, bury a horizontal strip of wire mesh about 18-24" wide along the fence there, then run it up to fill the gap. Tie wire the old and new fences together. The dog will not be able to dig out, which he/she may try to do since it is used to going out there.
Old 02-13-2012, 05:06 PM   #10
In a little over my head
Electric wire along the bottom and one along the top. Two stings and you'll be able to disconnect it. My fence charger has trained half a dozen dogs at half a dozen houses.
ratherbefishing is offline   Reply With Quote
Old 02-13-2012, 07:46 PM   #11
I don't know what kind of charge those elect fences have, but if it is anything like those mini-tennis rackets that you use to kill bugs, it will work super well. I touched one of those muthas once, just to see what the bugs were dealing with, but I won't touch one again. I was amazed.... notice how I refused to say "shocked"?
Old 02-13-2012, 08:43 PM   #12
Learning Things Every Day
Jay 78's Avatar
Stack a layer or two of pavers along the fence line. Integrate them into some sort of landscaping.
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-13-2012, 09:34 PM   #13
i would just take some chicken wire and staple it along to bottem of the fence.or what you could do is get some cedar boards and screw them up over the opening.
woodworkingkid is offline   Reply With Quote
Old 02-13-2012, 09:36 PM   #14
Place tack board along the fence the dog won't cross it nor dig it up.
Nailbags is offline   Reply With Quote
Old 02-13-2012, 11:49 PM   #15
Stay-at-home GC
Get a bigger dog?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Tags
building, carpentry, dog, fence, yard
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-05-2010 12:44 AM
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 0 09-20-2010 02:39 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Privacy fence ideas perpetual98 Landscaping & Lawn Care 5 02-16-2008 11:39 PM
