Do The Wireless Garage Door Keypads Go Bad & Other Problem? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2012, 07:39 PM   #1
Rewards Points: 210
Do the wireless garage door keypads go bad & other problem?
I have a problem where the keypad does not work. The light doesn't come on to let you know its even getting power. I just put in a new battery to make sure but nothing.
My garage door works fine with both cars Homelink and the push button remote by the door going into the house.
I can't get the keypad to do anything.
Also, one side of my garage door sensors is red and the other is green but everything seems to work fine. I thought that if any were red then there was something wrong.
Ideas for either problem?
imola ghost is offline   Reply With Quote
Old 04-11-2012, 08:30 PM   #2
Rewards Points: 210
Alright I found out that one of the LED's is supposed to be red and the other is green, so I'm fine on this problem. I thought they were both supposed to be green.
Old 04-11-2012, 08:35 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Are you sure a button is not stuck "in" on key pad?
sublime2 is offline   Reply With Quote
Old 04-11-2012, 09:04 PM   #4
Rewards Points: 210
Its not, I took it off to check and you can hear it "click" like it should as you open it but I'll look a little closer at the button paying attention to how it acts.
Old 04-12-2012, 07:33 AM   #5
Battery good???? If yes, keypads do go bad, like everything else.
LED colors may depend on the manufacturer, some have one red, one green, some have both same color. The important part is that both are lit.
Old 04-12-2012, 06:48 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Those keyboards being outside are sensitive to moisture(humidity) and salt air, in Fl I know you have both. I maintain a property on the ocean in SC, those keypads and wireless door bell buttons last a year.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-12-2012, 06:53 PM   #7
I have been doing garage doors and opts for 6 years and sounds like you have a bad keypad. Depending on year and model you can get a new one or a universal one.
jeremyporter88 is offline   Reply With Quote
Old 04-12-2012, 09:36 PM   #8
Rewards Points: 210
I figured out what the problem was. I took the keypad apart and found that one of the battery terminal wires was lose from the circuit board. I went to Radio Shack and bought a new battery terminal (9volt) removed the old one and soldered the new one to the circuit board and everything works perfectly.
The Following User Says Thank You to imola ghost For This Useful Post:
ariscus99 (04-14-2012)
Old 04-12-2012, 10:05 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Good job!
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Problem with garage door side entry thundercloud Carpentry 6 06-09-2009 07:27 AM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 08:44 AM
