Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-18-2009, 01:06 AM   #1
Do they make wedges to break concrete or rock??
I saw on one of those TV shows they had a wedge system of some sort . They drilled a huge rock and used the wedges to split off smaller manageable chunks. What are those called?? And do the box stores sell similiar ones?? Or where does one find those??
4just1don is offline   Reply With Quote
Old 08-18-2009, 04:12 AM   #2
paper hanger and painter
chrisn's Avatar
http://www.miconproducts.com/wedges.html
Old 08-18-2009, 05:30 PM   #3
thanks Chrisn,
Looks like a good site,,wish they gave aprox prices of products there,,guess I will call when I get the chance.
Anybody see these things at mennards,,,since that is the only big box store we have here??
Old 08-18-2009, 06:34 PM   #4
Originally Posted by 4just1don View Post
thanks Chrisn,
Not really a big box store item.
Masonary supply would be your best bet.
Ron
Old 08-18-2009, 07:08 PM   #5
Household Handyman
Why am I thinking the tool needed are called "feathers and wedges"? Maybe I'm too old school. It seems they used to use a "star" drill, hand held, and hit with a heavy hammer to drill a hole in the stone, then insert the "feathers and wedges" into the holes, then tap each wedge in turn until the stone splits. I suppose they now have automatic devices to do this now. Thanks, David
Old 08-18-2009, 07:21 PM   #6
Licensed P.E./Home Insp
Aggie67's Avatar
I caught this tip on the contractor's site. I cannot wait to try this stuff. I have a huge footing to demo in September.
http://www.dexpan.com/index.html
Aggie67 is offline   Reply With Quote
Old 08-18-2009, 07:52 PM   #7
Household Handyman
Thanks Aggie67- -I have an annoying neighbor who needs his driveway busted up, whether he knows it or not. This will do the trick. Thanks, David
Old 08-18-2009, 09:27 PM   #8
Moderator
Termite's Avatar
Feathers and wedges are still used quite a bit. I don't know of a better way personally...We see them used quite often around here.
Old 08-18-2009, 11:30 PM   #9
Concrete & Masonry
Feathers & wedges are indeed ideal for small stone work.
If your interested in a simple way to demo concrete, a firewood splitting wedge often works very well.
Commercially, at least from stone suppliers, the F&W approach has long since been replaced by hydraulic breakers.
jomama45 is offline   Reply With Quote
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 07:44 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
