Do Plastic Pipes Have A Shelf Life? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 08:37 PM   #1
Rewards Points: 154
Do plastic pipes have a shelf life?
I was doing some maintenance of my irrigation system, replacing sections of pvc schedule 40 and 80, 1/2" and 3/4". A stock of material I've had sitting around for at least 8 years seems very brittle, cracking under the pressure of my ratching cutter. Normally my cutter cleanly slices through. Does this stuff age to a point where you shouldn't use it? Should I throw it away and buy new material?
ovahimba is offline   Reply With Quote
Old 09-28-2008, 05:45 PM   #2
Rewards Points: 1,222
Only if it has been sitting out in the weather.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 09-28-2008, 08:56 PM   #3
Registered User
Termite's Avatar
In the weather, specifically sunlight! Ultraviolet light will deteriorate PVC. That's why the code requires that PVC vents that penetrate the roof must be painted.
I'd toss it out and get some new PVC just to be safe.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Quikrete Shelf Life jrepp Building & Construction 8 01-16-2008 02:40 AM
Masons: Smoke Shelf removal? BarryKaraoke HVAC 4 01-12-2008 07:31 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
Where to find 2" square plastic drain pipes The_Flash Roofing/Siding 4 07-25-2005 08:35 AM
