Do I Need Pressure Treated Wood For Outdoor Project? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 03:18 PM   #1
Rewards Points: 78
Do I need pressure treated wood for outdoor project?
I am trying to make some outdoor 2x4 furniture and I was curious if I needed to use pressure treated lumber if the projects are going to have a finish on them? I don't want them painted, but I saw an arbor/bench at Lowes for $200 that looked like about $20 of pine with a darker stain on it.
Let me know your thoughts, thanks.
gijoe985 is offline   Reply With Quote
Old 03-20-2012, 03:23 PM   #2
Ironlight's Avatar
You should NOT use pressure treated lumber for anything that is going to come into routine contact with skin. So the answer is no, use pine and then finish/seal it with stain.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
Hardway (03-20-2012)
Old 03-20-2012, 03:32 PM   #3
Rewards Points: 78
That's what I thought, but someone told me that I needed it so that it would handle the weather. I figured if anything I'd need pressure treated 4x4s for the uprights if I were to bury them underground.
Any special instructions/requirements for the stain/finish? Something that would help it last longer?
Old 03-20-2012, 04:26 PM   #4
Civil Engineer
Rewards Points: 4,568
A lot of outdoor furniture is built using naturally rot resistant wood, for example redwood, some types of cedar, mahogany, and teak are all used. I don't think I understood the part about burying the furniture in the ground, perhaps you have someone in mind you plan to strap down to the chair while you bury them? Hard pine works as long as you paint it well with a quality outdoor paint, but if you don't want to paint, one of the types of wood I mentioned can be used without treatment.
Old 03-20-2012, 05:18 PM   #5
Rewards Points: 78
I meant to bury the posts if I were building an arbor....
How much do those woods costs vs pine? Like a 2x4 of cedar or redwood?
Old 03-20-2012, 05:25 PM   #6
pine not much.
cedar lots more.
red wood way lots more.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
PaliBob (03-20-2012)
Old 03-20-2012, 05:37 PM   #7
kwikfishron's Avatar
Rewards Points: 178
Originally Posted by Hardway View Post
pine not much.
cedar lots more.
True story but the cost of Red Cedar vs. Redwood depends on where you live, on the West Coast anyway.
kwikfishron is online now   Reply With Quote
Old 03-20-2012, 05:55 PM   #8
that make sense.
Old 03-20-2012, 06:25 PM   #9
Civil Engineer
My issue with pine, particularly low grade pine as you typically find at the big box stores, is that it rots quickly, it splinters easily, and it is often pitchy and hard to paint and impossible to stain effectively. I have a teak bench outdoors, I bought it from one of those garden stores about 20 years ago, it is still in excellent condition, just needs a little washing once in a blue moon to restore it to near new condition. It has never been stained, painted, or oiled. No splinters.
Now you may not like teak because of political concerns and sustainability issues, and I respect that. However, this bench did not cost a whole lot more than an equivalent bench out of cedar, or hard yellow pine, or any other wood for that matter, and it looks great, feels nice, and does not rot. I built my deck using ipe for the same reason, needs no treatment, does not rot, does not splinter. And as for cost, never assume that one material costs less than another until you check local availability and pricing. I was astonished at the fact that ipe, a Brazilian hardwood, is less expensive in my area than western red cedar, redwood, or top quality douglas fir. You gotta check first, then decide. Personally, I would never build outdoor furniture from pine, too many issues, but to each their own.
Old 03-20-2012, 11:50 PM   #10
Registered User
Rewards Points: 5,216
Teak is very tough: http://www.google.com/search?client=...iw=828&bih=466
Gary
Old 03-23-2012, 12:59 PM   #11
Rewards Points: 78
Someone just suggested to use pine with a UV protective deck finish. Any thoughts?
Old 03-29-2012, 11:26 AM   #12
Rewards Points: 78
Hey, I'm still curious about your thoughts on pine with UV deck finish... This is going to be for some high school students doing group projects. We're trying to keep costs down. Although I don't want things to cost a lot, I also don't want things looking like junk...
Old 03-29-2012, 11:37 AM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
If your trying to go cheap....pine will work...not something I would normally use...
But if you use pine....seal it with something like Thompsons. You can stain it first if you want....but you can also get Thomspons with stain in it....
With pine....just plan on having to refinish it every couple of years....
ddawg16 is online now   Reply With Quote
Old 03-29-2012, 11:42 AM   #14
Rewards Points: 78
That is what my friend(another shop teacher) told me...
Old 08-21-2013, 08:15 AM   #15
Gymschu's Avatar
Rewards Points: 476
DO NOT USE THOMPSON'S WATER SEAL. It is the cheapest, worst of the clear wood sealers. Its' effectiveness is for about 3 months. Get something like Flood Co's CWF-UV. It doesn't cost a lot, has uv protection built in and it looks good.
Pressure Treated Wood Dimensions stymie222 Building & Construction 12 04-29-2011 10:55 PM
Green vs dark brown pressure treated wood acerunner Carpentry 5 02-22-2011 05:36 PM
Pressure treated wood? sharp Building & Construction 5 04-13-2010 08:50 AM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 11:02 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 10:53 AM
