Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-27-2011, 01:38 PM   #1
do i need to hire a chimney sweep?
just wondering if, since my chimney has a cap to prevent birds etc from nesting in there, do I really need to hire a chimney sweep, or is it a waste of $?
how often do you all have your chimney swept?
(i have a combination oil burner / hot water heater, and a fireplace that I never use.)
19mquinn79 is offline   Reply With Quote
Old 09-27-2011, 02:38 PM   #2
Is this wire Hot?
Oh-Fudge's Avatar
I clean my own every year with a chimney brush. I'm sure some (chimney sweeps) will tell you "you must have it inspected by a (expensive) professional every year!". But I burn mine many times every year and have no problems. And heck, isn't that what fire insurance is for? (wink)
Good link for chimney cleaning supplies. Climb up on the roof and measure your flue size and get the proper brush and extension rods:
http://www.northlineexpress.com/chim...y-brushes.html
Sorry, that appears to be a bad link, try this one:
http://www.northlineexpress.com/fire...cessories.html
Oh-Fudge is offline   Reply With Quote
Old 09-27-2011, 03:33 PM   #3
Oil fired devices produce a lot of soot. The chimney should be cleaned every year, from top to bottom. Pull the stack pipe and you'll find a pile of debris at the base of the chimney.
The fired clay liners deteriorate at the top of the chimney first. Also check the connections between sections to make sure the mortar is completely filled in. This is especially important with the fireplace as embers can get out and hit framing, starting fires.
Ron
B. Franklin 1759
Old 09-27-2011, 10:26 PM   #4
joed's Avatar
Unless you look down (or up) the chimney you can't tell if it needs to be cleaned.
Do not PM with questions that can be asked in a forum. I will not respond.
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Chimney Confusion (Long) wehcyar Building & Construction 7 09-03-2008 10:09 AM
Roof Leak Around Chimney robertr4836 Roofing 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
