-   -   Do Any Contractors Take Credit Cards?? (http://www.diychatroom.com/f2/do-any-contractors-take-credit-cards-25001/)
rlf1217 08-11-2008 01:45 AM
I desperatly want to build a 400 sq ft edition on top of my Ranch home with bathroom and steps going upstairs. I gotta assume the cost would be between $10k - 15k. ?
I need to find GC's who accept Credit Cards.
AtlanticWBConst. 08-11-2008 07:18 AM
I seriously do not see an addition (bathroom), even the size that you say, costing that amount of money (no way, not even close).
Personally, I think that you are off by at least 1/2 the total. I suggest that you start at $30K for adding a 2nd floor bath with stair access. There is alot involved with alterations. Example: It's highly doubtful that your existing ceiling joists will support the added weight.
rlf1217 08-11-2008 07:33 AM
Thanks for the reply Atlantic. Well, I forgot to mention I'm an electrician so there's $8,000 saved for the electrical work. I know I was low with my numbers but I'm sure I can get close. In fact I'll do the painting and trim work.
You are correct saying that the current structure migvht not support the weight.
Built in 1950 single story Ranch. Basement ceiling joists are 2x10 but main level ceiling joists are 2x6.
Do we need to worry about the wall structure too ie: plates and 2x4's? Or how about the basement cinder blocks?
AtlanticWBConst. 08-11-2008 03:04 PM
If your 2x4 walls are 16" OC framing, and everything else looks up to snuff, then you may be good. Your foundation would also need to be able to support the added load.
Additionally, you might want to check with your local inspectional offices to see what they would need submitted for such a project. I am sure that they will want drawings, engineer specs on how you will support the added load, maybe even architectual plans (?) = $$.
