DIY Tips And Tricks! - General DIY Discussions - Page 10 - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 10:42 AM   #136
Rewards Points: 780
Skin So Soft from Avon takes Great Stuff foam off of skin. You have to rub it in, but it works pretty well.
gma2rjc is offline   Reply With Quote
The Following 2 Users Say Thank You to gma2rjc For This Useful Post:
Evil Scotsman (11-30-2010), operagost (05-06-2011)
Old 11-29-2010, 10:48 AM   #137
the Musigician
DangerMouse's Avatar
As hard as that stuff is to get off your skin, you should make that post it's own Sticky thread! LOL
DM
Old 11-29-2010, 10:49 AM   #138
the Musigician
So does a belt sander, but I bet the Avon stuff is much less painful.....
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
quincy (11-29-2010)
Old 11-29-2010, 10:56 AM   #139
Rewards Points: 780
Yep, and it smells prettier too. Not that you guys want your hands to smell pretty. But a little soap and warm water takes care of that.
Old 11-30-2010, 12:09 AM   #140
jlhaslip's Avatar
Rewards Points: 2,884
Works as a Mosquito repellent as well.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
gma2rjc (11-30-2010)
Old 11-30-2010, 09:50 AM   #141
Totally screwed together
Getting oil stains out of clothes
My tip for getting oils out of clothes:
Murphys Oil Soap: Pour it on the oil stain and rub it in, treat it like a stain remover. Pulls it out e very time.
xxPaulCPxx is offline   Reply With Quote
The Following User Says Thank You to xxPaulCPxx For This Useful Post:
DangerMouse (11-30-2010)
Old 11-30-2010, 10:54 AM   #142
Rewards Points: 150
Originally Posted by skymaster View Post
Mouse; white,rye or whole wheat?
White WITHOUT the crust
Evil Scotsman is offline   Reply With Quote
Old 11-30-2010, 11:12 AM   #143
Rewards Points: 150
PS:
If you're doing a job that requires you to change the blades on your utility knife a lot, a small bottle with a childproof cap makes a good container to keep used razor blades in so you don't have to throw them in the trash loose where someone could get cut. The cap won't come off if it gets bumped or dropped.
Old 11-30-2010, 12:11 PM   #144
Rewards Points: 150
Upgraded the CB panel, but now don't know which breaker covers what? PLUS 60's house nothing is logical. My son and I went to each room and outlet, put a piece a blue tape on the wall near each and threw breakers until it went out. Then were able to walk around the house and list each one and label the CB panel. A little time consuming but is working like a charm.
Old 11-30-2010, 12:31 PM   #145
Doomed DIY'er
Buy tape measures which have both inch and metric measurements.
I work for a furniture manufacturer that transitioned to metric several years ago. They found that it could days if not weeks for a completely untrained person to accurately read in inches down to 1/32" accuracy. It takes about 30 minutes for someone to learn how to read with 1mm accuracy (just a hair over 1/32"). So, if you have someone helping who had dubious tape skills, have them use the metric scale.
I personally use metric almost all of the time because it's easier to read and to make complex calculations. If I have a board I want to split into 4 equal pieces, it's a lot easier to do that math in my head when it's 1218mm with a 4mm kerf then 47 7/8" with a 3/16" kerf.
clayman is offline   Reply With Quote
Old 11-30-2010, 02:09 PM   #146
jlhaslip's Avatar
I've been using both types of measurement for about 30 years and own tapes that are Metric OR English. Rarely use the combination ones. Too confusing and prone to error.
Google "Gimli airplane" to see what happens when the conversion fails.
http://en.wikipedia.org/wiki/Gimli_Glider
Old 11-30-2010, 02:45 PM   #147
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
Wow, that was one heck of a read jl, they were really blessed to have a pilot who knew how to glide.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-03-2011, 06:37 PM   #148
the Musigician
You know those "pads" you can buy to put underneath furniture to let it slide easily? You can make them yourself.... from a plastic milk jug! Just snip this shape, (or more ends for a rounder bottom, like a flower), fold at red lines and duct tape them to the legs and slide away.
DM
jamiedolan (03-03-2011)
Old 03-03-2011, 06:46 PM   #149
Rewards Points: 780
Does it matter what kind of milk jug it is - from 2%, skim or whole milk?
... just giving you a hard time DM. Great tip.
Old 03-03-2011, 06:50 PM   #150
the Musigician
300,000 comedians out of a job.......
DM
Tags
great stuff , skin so soft
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 09:52 PM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 08:58 AM
Help :( Looking for tips on fishing PEX between floor joists .. drh HVAC 5 05-29-2008 09:26 AM
tips to become a pro painter chrisusvi1 Painting 2 07-29-2007 05:53 AM
removing carpet tips... biikman Flooring 4 10-02-2006 12:04 PM
