DIY Tips And Tricks! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-28-2008, 08:53 AM   #1
the Musigician
DangerMouse's Avatar
DIY Tips and Tricks!
i saw a commercial for ProCaulk today. it's a square(ish) rubber 'tool' for smoothing caulk as you do tubs, etc. i thought to myself, "self, you already DO that!" what i've always done is cut out that same shape more or less from an old plastic milk jug! they have various thicknesses on a jug so you can make it as 'stiff' as is comfortable for you.
i also use the jugs as guitar picks! free, various mm thick and always disposable. i use thick from the bottom for my bass picks, and thin from the side for my 12 string. they're better than a lot of purchased i've used only to have them crack in half during a heavy jam on stage. they NEVER break!
anyone else have any diy tools/tricks they'd like to share here?
DM
Old 12-28-2008, 11:06 AM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Humm.... i use napkins as my coffie filters :p
Toss them picks out (well maybe keep acouple for the 12 string) for the bass and 6 use your fingers !
Its been awhile but if you grow and then trim your nails to the right lengh (with your teeth of course) they work great, so much more control, easyer to mute... atleast for me.
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 12-28-2008, 11:21 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For latex based caulking, the best shaping tool is what is at the end of your arm: Your fingers (to wipe it down)...
- Build Well -
Old 12-28-2008, 11:48 AM   #4
Registered User
Termite's Avatar
Bread wadded up and jammed in a copper pipe to prevent water from getting at the joint while soldering. Works great.
Old 12-30-2008, 03:40 PM   #5
So has anyone used this thing? Is it a total gimmick?
cambruzzi is offline   Reply With Quote
Old 12-30-2008, 03:52 PM   #6
the Musigician
i imagine it'd work just fine, kinda pricey though. cut it out of a milk carton.....
DM
Old 12-30-2008, 04:58 PM   #7
Custom Cabinet Maker
Mouse; white,rye or whole wheat?
skymaster is offline   Reply With Quote
Old 12-30-2008, 06:20 PM   #8
the Musigician
multi-grain
DM
Old 12-30-2008, 06:52 PM   #9
Man; dont dem little par tickles kinda mess up da aero ater?
Old 12-30-2008, 07:46 PM   #10
DIY Expert in Training!
I had to drill out holes for electrical wiring today...to get the 1 1/4" depth I cut a piece of 2x4 and nailed it to another. I just use it as my quick guide.
gone_fishing is offline   Reply With Quote
Old 12-30-2008, 07:49 PM   #11
Rewards Points: 2,906
Here's a DIY'er tip:
When replacing a light fixture, DON'T disconnect the old fixture at the wire nut connecting the old fixture to the house wiring. The house wiring may have baked insulation from being cooked inside the electrical box and handling that wiring may cause the insulation to break off. Instead, cut the wiring of the old fixture close to the fixture and connect to the old fixture's wires.
Also, when assembling any metal parts where lubricating the parts would be an advantage, but you're reluctant to use a lubricant because dust would stick to it and possibly interfere with the operation of the machinery, remember that glycerine has the lubricating properties of a light oil but evaporates completely without leaving a residue. You can buy glycerine at any pharmacy.
The best way to avoid brush strokes when painting with a brush is to thin your paint. Adding thinner both allows the paint to self level faster and increases the drying time of the paint so that it has more time to self level. Thinning the paint results in it drying to a smaller film thickness, so you need to compensate for thinning by applying an additional coat.
Before painting with any brush, clean it with the thinner of the paint you'll be using. If you'll be using a latex paint, wash the brush out with water. That will allow water to be absorbed by capillary pressure high up into the brush's bristles. This prevents the paint that gets high up in the bristles from drying out while you're painting so that when you do wash the brush out, ALL of the paint comes out easily and quickly. It also prevents "hard heel" syndrome in brushes cause by paint drying high up in the bristles.
Removing a stubborn hinge pin from a door hinge is best done by gripping the head of the hinge pin with a small pair of locking pliers and twisting the hinge pin back and forth in the knuckle while pulling on it.
To prevent faucet knobs from sticking to the top of the faucet stems, apply some antiseize compound to the knob or stem top before screwing the knob on.
You can clean mildewed silicon by mixing bleach and talcum powder (aka: magnesium silicate) to make a paste. Trowel the paste onto the mildewed silicone, cover with Saran Wrap so the bleach doesn't dry out, and leave it for a couple of days like that.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
The Following User Says Thank You to Nestor_Kelebay For This Useful Post:
Evil Scotsman (11-30-2010)
Old 12-30-2008, 09:50 PM   #12
Registered User
Termite's Avatar
Sorry to be a funsucker on this thread but...
That may be a DIYer tip, but it sure itsn't a good idea.
This method adds an unnecessary connection and involves using pigtail wiring from the previous fixture to connect to the new fixture's pigtail wiring. It also puts faith in the connection made by the person that installed the last fixture, and the pigtail size of the old may be smaller than that of the new. I have never seen a professional electrician do that on any sort of retrofit electrical work, and I'd never consider doing that myself. Hardened insulation on household wiring will strip off enough to facilitate proper installation of the new fixture's pigtail in a wire nut.
Old 12-30-2008, 11:01 PM   #13
OK, KCTermite, here's one to replace it:
HOW TO MAKE A TEST TUBE DISAPPEAR:
Immerse a test tube in corn oil. It will become completely invisible when it's immersed in corn oil.
That's cuz the refractive index of corn oil is 1.470 to 1.474
http://www.corn.org/CornOil.pdf (page 15)
and the refractive index of Pyrex glass (which test tubes are made of) is 1.473
http://www.valleydesign.com/pr16.htm
So, if you immerse a test tube in corn oil, it will become invisible because almost no light will reflect or refract at the oil/Pyrex interface(s). Thus, light travelling through the corn oil will behave almost exactly the same way whether it goes through a test tube not. That means, the test tube will become invisible.
You gotta know about refractive indices to get your DIY'er arm badge in Invisibility.
Old 12-30-2008, 11:09 PM   #14
Registered User
Termite's Avatar
Just today I was on a jobsite trying to figure out how to make a test tube disappear.
Nestor, take your medicine!
Old 12-30-2008, 11:31 PM   #15
K&B Remodeler/Tile Guy
angus242's Avatar
Never set your cordless drill down on the battery. It's much safer to lay it on its side....on the floor. If you place it on a counter top sitting on its battery, you can VERY EASILY knock it over and where it stops, nobody knows!
Ask me how I know....
Angus
My Albums
angus242 is offline   Reply With Quote
Tags
great stuff , skin so soft
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 09:52 PM
Carpeting Stairs - Tips 'n' Tricks? DanTheMan Flooring 1 08-20-2008 08:58 AM
Help :( Looking for tips on fishing PEX between floor joists .. drh HVAC 5 05-29-2008 09:26 AM
tips to become a pro painter chrisusvi1 Painting 2 07-29-2007 05:53 AM
removing carpet tips... biikman Flooring 4 10-02-2006 12:04 PM
