DIY Spray On Concrete? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-02-2007, 10:46 PM   #1
DIY Spray on Concrete?
Does anyone know of a spray on application I could use to cover the original foundation on a house? The concrete foundation comes up about 1 1/2 feet or so above ground and is pretty ugly. I'd like to cover it, but don't want to have to trowel on quick-set around the entire house.
I'd also like to use it on some concrete that was poured previously next to the house. This concrete is extremely rocky, the aggregate is on top and I'd like to cover it.
Thanks!
tacticle_blunder is offline   Reply With Quote
Old 10-02-2007, 11:14 PM   #2
Hi tacticle-blunder
Yes there are several things for that. I don't know the names of them but I was looking in my small hardware store here in town for something for my roof and saw all kinds of paint and liquids for concrete. Waterproofing as well as paintlike coverage. If you're thinking of something more like a sprayable concrete to recoat the foundation work .... I would suppose a very loose mix of that quickrete in a sprayer (or bottle) with a large spray hole might work for you. I haven't done that but seems as it would work as you want to basically white wash it and hide its ugliness not add any support to it. It'd be sort of like the old fashioned lime wash people used to paint on their walls. If it comes out clumpy then its not thin enough and if it comes out too much like water and just runs off then too much water. So I'd mix a small batch and see how it works before adding water to the whole container of it. But I have added EXTRA Water to the Quickrete and it still does set up.
Simbabluenobi is offline   Reply With Quote
Old 10-04-2007, 03:48 PM   #3
I tried the spray methods mentioned above, no love. I tried with both an electric paint sprayer and manual pump sprayer. Concrete is just too thick! I was using the concrete finishing mix which is the least viscous I could find. It has no rock etc. I mixed it very wet, probably too wet to do any good but still no luck. Think I'll have to do this the hard way
Old 10-04-2007, 05:55 PM   #4
Rewards Points: 5,336
I don't think you're going to find a spray on concrete you do by your self. You would look to the tool rental places for that option. Pool installers use it, you might try calling them. Look for gunnite in the listing. Otherwise, it's the trowel.
Ron
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
