Is This A DIY Project - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-20-2014, 10:00 PM   #16
Administrator
Cricket's Avatar
Rewards Points: 640
I am truly sorry you are having trouble with the ads. We are listening. We do care. They are actively working on solving the issues. Unfortunately, I cannot see the issue because it isn't happening for me but we are working on it. I promise.
Cricket is offline   Reply With Quote
Old 01-21-2014, 02:44 AM   #17
Rewards Points: 324
I don't have any issue with the ads either, but that is only because I run Adblock Plus, and have it set fairly aggressively :-)
As for the OP's problem, I would get a pro to weld it, and check the integrity of any other critical welds while they're at it--properly done, the welds should be as strong as the metal being joined.
mgp roofing is offline   Reply With Quote
Old 01-21-2014, 04:15 AM   #18
Rewards Points: 4,752
yep, either a pro to weld/braze it OR buy a new 1 - chances are new is less $, mstrlucky
guys, we often see apron/vest stores listed as selling ' GOOD ' goods ? i'm bettin' it came from there - its was cheaper than specialty railing, available right then when you wanted/needed it, & certainly the store was closer to you,,, IF true, its likely chinese pot-metal & can't be properly repaired.
this railing's original price is probably nowhere near the cost of well-built railing but we all buy there,,, many of us don't even realize there are different grades of power tools - apron/vest & pro - same w/lumber
its no consolation we've got to replace 87 condo stair railings that came from the same place,,, good luck !
Old 01-21-2014, 06:38 AM   #19
Rewards Points: 147
The problem seems to be related to the proportions of font size. If I zoom the text big enough to read the post comfortably the ad sizes will overlap the text.
Also, for me that bright blue default scheme hurts to look at. The 2013 one is much easier on the eyes.
Rango is offline   Reply With Quote
Old 01-21-2014, 07:01 AM   #20
Ole Wood Worker
BigJim's Avatar
Rewards Points: 592
Strange, if I increase or scroll the default screen size, all the ads disappear. I am on Windows XP Pro and have my screen resolution set as low as it will go, I don't know if that has anything to do with it or not. If my screen default is 100% the ads over lap the screen, so I increase the default to 110% and I am good to go.
We know it isn't the Admin now, it is the Techs who aren't getting it right.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-21-2014, 07:17 AM   #21
Rewards Points: 147
It's possible it's more browser related. I'm on Iceweasel (Debian's Firefox) and zoom in or out. The ads and photos on the right get bigger and the text in the posts increase while the text column gets narrower until it gets overlaped by the photos.
With Chromium (Linux Chrome) the same thing happens until the ads disappear but the font is huge at that point.
My android tablet does pretty much the same with the its' browser.
Old 01-21-2014, 07:33 AM   #22
wow, talk about hijacking a thread
Old 01-21-2014, 12:49 PM   #23
Rewards Points: 33
That's absolutely the problem. Most websites look best in 1024x768 or higher. If you have it lower than that, I'm surprised that this is the only site causing issues.
There's also a DIYChatroom mobile app for those on iPads and Android devices.
venator260 is offline   Reply With Quote
Old 01-21-2014, 02:27 PM   #24
An old Tradesmen
Rewards Points: 7,826
Admin okay-ed it. LOL
Old 01-21-2014, 02:38 PM   #25
joed's Avatar
Rewards Points: 13,358
They may look best at those resolutions. But a properly designed website will either shrink to fit your screen or the screen will have scroll bars to move around and view it. Stuff should not be overlapping because of screen size.
The Following User Says Thank You to joed For This Useful Post:
Cricket (01-21-2014)
Old 01-21-2014, 02:42 PM   #26
Administrator
Cricket's Avatar
Rewards Points: 640
Let's get back on topic now.
The Following User Says Thank You to Cricket For This Useful Post:
Mstrlucky74 (01-22-2014)
Old 01-21-2014, 08:12 PM   #27
Rewards Points: 236
i agree about have the rest of that rail checked. that should never break, for ANY reason.
what you have is a fine example of what is called a "cold weld". it looks and seems to be a good weld, to the ignorant. but it is little more than glued together. just today, i had to fix someones cold weld. my weld would not break if ran over by a train, literally.
that fix is not diy for a nu-be.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 01-22-2014, 04:58 PM   #28
Rewards Points: 626
That would be a Tig weld and a lot of prep work to get it down to bare metal then tack it and then work the cup in a very tight spot.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Drywall project: New basement bathroom NetTractorTalk Drywall & Plaster 15 10-03-2012 12:23 PM
Troubleshooting 3 switches in one box for bathroom project Jerrys84 Electrical 11 08-01-2012 02:48 PM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 09:30 PM
Interesting Project Mcamnl Electrical 14 05-27-2009 01:13 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
