DIY Power Washer? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 11:11 AM   #16
What I did in a pinch was create a wand using 1/2" PVC that has a valve that can also attach to your garden hose. At the end of the wand I put on a cap and drilled two tiny holes in it. I used it for a tunnel boring machine to get pipe under a walk way and I tried it against the house and it did a great job. It also works well on cleaning dirt bikes after a dirty ride.
I think the key is having good water pressure to start with.... and the valve is a necessity. You could also use the same set up with a spray nozzle that's threaded at the tip to recieve the PVC want, in which case you would not need a valve.
Hope that helps.
John
john37 is offline   Reply With Quote
Help! Mystery power in complex 3-way! mnyman2003 Electrical 12 12-16-2007 01:10 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
