DIY Garage Spraybooth - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 09:17 PM   #1
DIY garage spraybooth
I do wrap doors and spray wood glue on the super wood before wrapping the doors. I do have to construct a spray booth. I am thinking of installing a low pressure fan with a high flow rate in stead of an extractor fan. I will make an opening in the wall for the air to exit. Will it work?
Akkerwillie is offline   Reply With Quote
Old 01-10-2012, 09:20 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Huh?
Do you use a mask?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-10-2012, 09:33 PM   #3
Originally Posted by titanoman View Post
Huh?
Do you use a mask?
My thread is not about the use of a mask
Old 01-10-2012, 09:36 PM   #4
Well....... my thread is not about the use of a mask
Old 01-10-2012, 09:44 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Akkerwillie View Post
Will it work?
Probably.
Well, until your neighbor and/or the fire Marshall gets wind of it.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Akkerwillie (01-12-2012)
Old 01-10-2012, 09:49 PM   #6
garage spraybooth
Originally Posted by TarheelTerp View Post
Probably.
I did not mentioned i dowork in an industrial area and will make use of a filter before the air escape
Old 01-10-2012, 10:48 PM   #7
Rewards Points: 2,210
The HVAC section may be of more help.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Old 01-10-2012, 10:53 PM   #8
MarginallyQualified
or go to the real pros:
http://www.devilbiss.com/Resources/F...3/Default.aspx
Old 01-11-2012, 08:51 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
A filter on the front end would also be useful for keeping neighborhood dust out of your booth.
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 01-11-2012, 03:35 PM   #10
Hardcore DIY'er
Huh?
Do you use a mask?
If not it may be too late.
EvilNCarnate is offline   Reply With Quote
Old 01-11-2012, 04:32 PM   #11
Disabled wood vet
titanoman's Avatar
That's what I'm thinking lol!
The Following User Says Thank You to titanoman For This Useful Post:
EvilNCarnate (01-12-2012)
Old 01-11-2012, 04:33 PM   #12
a garage spay booth is a dangerous proposition. it can be done but please be sure to check all local codes. you will have to spend quite a bit of $$ for vapor tight lighting and outlets. good luck.
rodu is offline   Reply With Quote
Old 01-11-2012, 05:23 PM   #13
A Little Of Everything
Rewards Points: 1,364
Yes, you can do this. Years ago, I did something similar in order to paint a car. I used heavy plastic drop-cloths.
It is not an ideal set up, by any means, but can work temporarily.
You're going to run into several potentially serious issues:
1. Combustible materials that could explode.
2. Outside debris being sucked into the booth & contaminating the product.
As others have suggested, you might want to check with local building codes & ordinances.
DrHicks is offline   Reply With Quote
Old 01-12-2012, 07:40 AM   #14
Mold!! Let's kill it!
Rewards Points: 2,012
Is the stuff you are spraying flammable? Is it meant to be sprayed? Certain materials are combustible, but can become flammable when atomized through a sprayer. You should be able to tell from the MSDS or manufacturer's info. The characterisitcs of the material are important to the design of your booth. You need to be careful with positive/negative air pressure relationships with the rest of the building. Pushing air into a spray booth can cause a positive relationship relative to the space outside of the booth. Air inside will leak out of every gap taking spray fumes or particles with it. You also need to consider "make up" air to replace that which you are exhausting. Will it come from the rest of the shop area and if so how does that air get replenished? Relief air dampers on an outside wall? Do you have capacity to condition the relief air (heat or cool it)? If necessary, you need to consider explosion proof lighting. Static discharge?
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Akkerwillie (01-20-2012)
Old 01-12-2012, 03:48 PM   #15
praybooth
[quote=EvilNCarnate;819582]
If not it may be too late.[/quot
YES I AM USING A PROFESSIONAL TYPE OF MASK RECOMMENDED BY PROFFESSIONAL SPRAYPAINTERS IN SOUTH AFRICA AND DO NOT SMELL OR TASTE ANYTHING DURING OR AFTER SPRAY
DIY Garage Spraybooth Akkerwillie Electrical 8 12-10-2011 11:53 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
