Dishwasher Sink Vent - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 06:48 PM   #1
Question
Dishwasher sink vent
OK. I don't have a garbage disposal. But I need to know how to vent the dishwasher. How can I set it up to work in the drain/ trap?
dosoathome is offline   Reply With Quote
Old 04-14-2009, 10:33 PM   #2
Registered User
Rewards Points: 5,516
I am not a plumber....... Air gap
To prevent wastewater from draining or siphoning back into the dishwasher, many local codes require that the appliance be connected to an air-gap fixture before the disposal. The air gap, bought separately, mounts on top of the sink or counter right next to the sink and connects to two flexible hoses—one that runs to the dishwasher’s drain and another one that runs to the sink’s trap or the dishwasher inlet on the disposal. In some areas, codes allow looping the dishwasher’s drain hose in a high arc up under the countertop as an alternative to installing an air gap. Check your local B.D.
If your sink doesn’t have an unused hole for mounting the air gap, you’ll need to bore one in the countertop next to the sink using an electric drill and a hole saw or have the sink top drilled. I think there is a drain piece with that adpt. built-in, a real plumber should be along shortly. Be safe, GBAR
Old 04-14-2009, 10:38 PM   #3
Question
Under the sink?
Some friends mentioned they thought there was some way to attach it under the sink? Does it have to go through the counter? (There is no garbage disposal).
Old 04-15-2009, 09:30 AM   #4
Rewards Points: 3,130
If an air gap is required by local code, it must be installed above the overflow level of the sink. As noted, you can bore a hole to install it. If you can get away with looping the dishwasher drain hose, that's all done inside the base cabinet.
Tags
dishwasher , sink , vent
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 10:56 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 05:50 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 05:28 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
