Disgusted In FL, Shed - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 07:54 PM   #16
CDH
Rewards Points: 29
Look into building an ag barn, a lot of county's in Fl allow ag barns, I payed $75.00 for the permit so the county got their money, no inspection required, I built a 32x60 but your options are unlimited, they have some nice barn kits as small as 24x12 with metal trusses and galvalume tin roof, just a thought.
CDH is offline   Reply With Quote
Old 04-14-2013, 08:57 PM   #17
Rewards Points: 280
Thanks for the input. The ag barns are a no go in the Ft Myers area.
jjrbus is offline   Reply With Quote
Old 04-18-2013, 01:19 PM   #18
DIY & Installation
I am a builder of sheds and I am not a big fan of installing sheds in Florida. So many zone restrictions. Having said that, these strict regulations are there to protect the homeowner. If everyone built sheds and garages with 2x3 construction, they wouldn't last anyways.
storageman is offline   Reply With Quote
Old 04-18-2013, 05:30 PM   #19
Rewards Points: 5,974
I agree there needs to be some regs. But the pre fabs need to be held to the same standards, whice they are not.
Old 04-18-2013, 08:03 PM   #20
Rewards Points: 280
NO NO NO, the regulations are there to protect the pre fab shed suppliers!!
The shed companys are putting up morsels of defecation, while the home owner has to build a bomb shelter!
Just another disgruntled blow hard homeowner that thinks he knows it all you may think. Well I have the county supplied plans that I have to build to and I had a pre fab shed. Apples to oranges.
An example the shed company's can use 3 built up 2x6 for the skids, a DIY'er has to use continuous 6X6 and it gets worse from there. I have to use an earth auger anchor about every 3 feet both sides, the shed companys put one in each corner!!
Jim
Old 04-18-2013, 08:20 PM   #21
Rewards Points: 236
talk to your mayor, congressman, senator. you may be surprised what they can do.
Fix'n it is offline   Reply With Quote
Old 04-19-2013, 06:50 AM   #22
Rewards Points: 3,130
You seem to assume that because prefabs are available for sale, they are automatically legal where you live. That is most certainly not the case everywhere. My local big box store has lots of things for sale that are not code legal here or anywhere else.
I think you mentioned earlier in this thread that you ended up buying a prefab. I can't imagine you got a permit based on what you've said about your local building requirements. If you didn't, and one is required, you have broken the law.
Old 04-19-2013, 07:41 AM   #23
Household Handyman
Rewards Points: 1,408
I just read this thread today (April 19). This situation happened locally some few years ago. Someone, located about fifty (50) miles away started a local business here, built the sheds there, and transported them into this area. These sheds were as "jjrbus" described as "morsels of defacation", and did not meet this county's building code. After the local code inspectors shut the business down the business owners filed a lawsuit claiming that their product did not have to meet local codes as a customer could go to thier county, but the same product and have it delivered to this county somehow circumventing the local coding. The won. I know a number of home builders in this area and have discussed the construction of these units with them. They claim that they could not buy the material(s) for these units for the small amount that they were selling for. The local code enforcement found a loop-hole which allowed them to inspect the units once placed on site and condemn them immediately much to the home-owners dismay. After many law-suits by home-owners, the business finally closed their local location. They are still in business in their home county but now display a sign stating which county's these units will meet local business codes. I also believe that if you protest enough, both in writing and in person, to your local governing body that this issue would be resolved.
Old 04-19-2013, 07:54 AM   #24
You don't need a permit that is why they are on skids they are considered mobile units. If you build one without the skids you need several permits.
Old 04-19-2013, 09:25 AM   #25
It's not good to make such generalizations. What you say is most assuredly not true where I live. I had to get a permit and inspection for my Amish-built premanufactured shed that just sits on the ground. No foundation, water, electric, nothing. There is also no minimum size below which a permit is not required. The kicker: a few days after the inspector came, I got a Certificate of Occupancy in the mail. So I guess I could live in the thing if I wanted to.
Old 04-19-2013, 02:45 PM   #26
Rewards Points: 280
A permit is required for a shed in Lee county Florida, any size shed!
The only loophole in the system is trailers. As long as it is on wheels and is registered, you can keep it in your yard. That is what I did while I tried to beat the system, a 24' car hauler. I finally threw in the towel and bought a used shed.
But now I moved and need some storage.
Thanks for all the input and responses.
Old 04-19-2013, 03:54 PM   #27
I was not making a generalization I was talking about where I live.
Old 04-19-2013, 05:59 PM   #28
Rewards Points: 280
If you are not good to your wife, you may be living in it JIm
Old 04-21-2013, 06:21 AM   #29
Roger that. I wonder how comfortable a lawn tractor is to sleep on.
Old 06-09-2013, 06:23 AM   #30
Rewards Points: 280
Thanks for all the input, always appreciated.
Here I am again with another used shed! It is a 2006 10X16' SMithbilt shed in excellent condition. Bought for $1500 and delivered for $350. I have a quote here for the same shed new for $3400, delivered and setup, plus permit.
To my way of thinking a used shed appears to be the best option, I do not have to spend thousands for a piece of junk nor do I have to build a bomb shelter.
I have to get a permit and have this inspected, I believe the permit is now $175.
The whole process leaves a bad taste in my mouth! JIm
water run off in shed kathy k Building & Construction 4 08-09-2009 03:29 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
running uf to shed bobo60 Electrical 12 04-20-2008 01:41 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
