Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-27-2009, 09:13 PM   #1
Disgusted in FL, shed
I went and looked at a couple Lee county FL approved pre fabbed sheds and decided I could do a much better job for 1/3 the $$$. I went to town hall to get a permit. They even gave me a set of plans!!! OK for skids the pre fab's use 2 PT 4X4, the homeowner has to use 3 PT 6X6!!! The Prefab's use 2X6 for the floor, the homeowner has to use 2X8. The prefabs use aluminum or steel sideing screwed to 2X4. I have to use 1/2 inch plywood sheer panels at each corner nailed every 4 inches with double 2X4 at the end of each panel. Tthe prefabs use a 2 foot hurricane anchor, I have to use a 4 foot anchor.
Plus I cannot understand some parts of the plans. Whats a guy to do??
jjrbus is offline   Reply With Quote
Old 08-27-2009, 10:05 PM   #2
Man of many hats
wrangler's Avatar
I understand your pain. Here in NW Fla, we deal with similar codes that do not seem to reflect the best interest of the homeowner, but yet must be followed. As stated in a past post, I installed 32 double hung, double pane vinyl windows (and two sliding glass doors) in a three story house near the beach here in Pensacola... Hurricane Ivan came through and wiped out a good part of all houses near the beach. This house suffered ONE cracked pane of glass on the third floor where a pine tree hit the house but the rest was safe. Yet, two years later the insurance companies lobbied the state to make law that anyone that replaces windows must either have 'hurricane glass' or similar windows installed with a hurricane shutter system. While this seems like a good plan to reduce claims, what it really does is prevent those on lower or fixed incomes (retirees) from upgrading their single pane aluminum windows to something safer and more efficient.
Unfortunately, in your case, I think that the cheaper route is taking the lesser building that has been approved, though I would opt for building my own under the current code and KNOW that it is better, stronger, and YOU did it yourself!
Oft times, stricter requirements are set forth for home owners to ensure that safety and reliability is met. This isn't a bad thing, but definetly will add to your budget.
FMTCW, I would go ahead and build my own... it will be stronger and made the way YOU want it.
Man of many hats
wrangler is offline   Reply With Quote
Old 08-28-2009, 02:29 PM   #3
Thanks Wrangler. It would seem that the shed industry has a much stronger lobby than DIYers!!
If I could muddle my way through the code, I might try to build my own. Even the overbuilding they require would still come out cheaper.. I am looking at a 12x20 foot shed. The cost of a crappy prefab is $4500, a worse than crappy is $3600, I wont count the $36oo shed as I would keep my items in garbage bags first. I figure $3000 maximum for a DIY shed.
Its looking at the plans they have given me that is a big problem, I do not understand what they want. I'm not real sure they know what they want!!
My other option is an old school bus, I live in an unincorporated area so as long as I keep it registered it would be legal!!
Old 08-28-2009, 02:54 PM   #4
Rotaredom & Xtrem DIY'r
Scuba_Dave's Avatar
Are the plans what they require you to go by?
Or just plans that they hand out as an example?
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile(User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
Old 08-28-2009, 06:42 PM   #5
They are the actual plans you must go by. They have 6 sets of plans available 3 for masonary and 3 for wood. Anything else you must have drawn up and approved.
I was poking around on the net and found a set of plans for Osceola FL building dep. Limited to one size but very clear very well done.
Old 08-28-2009, 09:36 PM   #6
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
The local codes are just the minimum you must do to be legal, but not necesslarilly (sp?) the best way for your location. The budging plans are for the shed and do not reflect the local conditions.
What if your perfectly good shed was picked up and blown into an adjacent home causing damage? Will your or his insurance cover the damage?
Just take a look at the coastal requirements for new or replacement garage doors that were changed to save the roof of the home they are installed in. - Same doors different locations.
Dick
concretemasonry is offline   Reply With Quote
Old 08-28-2009, 09:50 PM   #7
Sounds like they really make you jump through hoops down there. I live in the mountains of Virginia and don’t even have to get a permit for a non permanent structure under a certain square footage. I guess there are advantages to living out here in the sticks. Good Luck!
Kris
www.buildashedhouse.com
kschmandt is offline   Reply With Quote
Old 08-28-2009, 10:58 PM   #8
What has me ticked off is I have to build a very strong structure while the prefabber's can sell real pieces of . Lets start at the bottom. The Skids. The prefabbed can use 2 PT 4X4's I have to use 3 PT6X6's A 4X4 here is about $7 a 6X6 is almost $20. For the shed I want that is $35 vs $100 .
There is NO rational explanation for the difference. Some one should be tarred and feathered and run outta town!!!!
Jim
Old 08-28-2009, 11:30 PM   #9
Theres more then one way.
iMisspell's Avatar
Can you post a picture of the plans (dont know if thats legal or not) ?
Maybe you are reading the prints wrong, and there are options (use one of "these" instead or two of "those") ?
In my head, i would agree, this makes no logical sence unless theres a bunch of red tape somewhere.
If you where to buy a shed - would that shed you bought have to meet these standard and the places around there are just selling crap (which no one gets inspected after they are bought and placed in the yard) ? I dout the stores care about code.
I would think (and by the sounds of things im probly wrong), but i cant picture Homedepot carrying a shed designed for each states code requirements, hence, what they are selling would not be legal for your area ??
Did you run the construction of the pre-fab sheds by the inspector and ask for an explanation ?
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 04-21-2010, 06:36 PM   #10
I caved in and bought a crappy prefab. I bought a used Ted shed 12X24 with garage type door and man door, delivered, permitted, setup and tax for $3000. The option was hire a FL licensed engineer to draw up plans and stamp them. Then I could build a piece of junk, just like the prefabbers.
JIm
Old 04-21-2010, 06:46 PM   #11
Scuba_Dave's Avatar
Thats a bummer. my pool cabana was 10x12
I added on 10x10 for maybe $3-400
More On This Topic
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
Watch a seasoned professional demonstrate how to wash French-pane windows in this free online video about home care. Read More »
An expert shows how to replace a window pane in a frame and how to slide it back into the window in this free DIY home improvement and repair video guide. Read More »
The best way to remove small scratches from window panes is with a gritty substance, such as whitening toothpaste that is applied with a paper towel or sponge. Use vinegar and water to rinse toothpaste off of a window pane with help from a professional... Read More »
Using free weights for straight biceps curls is a great way to build biceps muscles. Build stronger biceps with tips from a fitness director in this free video on muscle building and free weights. Read More »
water run off in shed kathy k Building & Construction 4 08-09-2009 04:29 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
running uf to shed bobo60 Electrical 12 04-20-2008 02:41 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
