Direction Of Hardwood Floors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-12-2008, 08:15 PM   #1
Direction of Hardwood floors
I have two halls that intersect. One is horizontal and the other one is veritcal. Hall one leads to the dining room and hall two leads to the bedrooms. Is it wise to change the direction of my flow where the two halls intersect?
kprice is offline   Reply With Quote
Old 03-12-2008, 08:31 PM   #2
Rewards Points: 1,232
I have never seen a vertical floor. Normally, we call that a "wall".
Tscarborough is offline   Reply With Quote
Old 03-12-2008, 08:36 PM   #3
Assuming you meant perpendicular instead of vertical, the general rule of thumb is to carry the long visual lines of the flooring parallel to the longest dimension of the room/hall. That is, the boards would run parallel to the longest distance, and any floors branching off would be laid parallel with that particular room or hall's long dimension.
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 11:20 AM
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 05:05 PM
where to get 1/4" thick hardwood floors? dozu Flooring 3 04-30-2011 05:17 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
