Digging Footers After Heavey Rain - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-16-2008, 02:00 PM   #1
Rewards Points: 230
Digging Footers after Heavey Rain
So its raining right now and it's been raining all day. It's supposed to stop sometime tonight around 10 p.m. It also rained (fairly heavily) earlier this week. I had originally planned on digging the footers (12" x 36") tomorrow morning (probably around 10 a.m.). My question is, will this be a problem in light of all the rain recently? Will I dig down one foot and hit water?? Thanks,
Kevin
PS - I just noticed that I spelled "heavy" wrong in the title but I can't edit it
Ler0y Jenkins is offline   Reply With Quote
Old 05-16-2008, 02:15 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
How far below the existing level and what kind of soil?
concretemasonry is online now   Reply With Quote
Old 05-16-2008, 02:38 PM   #3
Rewards Points: 230
The holes will need to be 36" deep and the soil is a lot of sand (I live in New Jersey).
Old 05-16-2008, 02:49 PM   #4
Registered User
Termite's Avatar
It is never good to pour on saturated soil if you can avoid it. Working in sandy soil is probably better than clay soil.
Water won't do much to affect the concrete itself. Concrete would cure just fine underwater if it had to, because it is a chemical process that doesn't require airflow.
I'd advocate waiting until conditions are a little drier if you can, just to make sure you're pouring on dry, stable soil.
Old 05-16-2008, 03:04 PM   #5
Rewards Points: 230
I'll only be digging the footings tomorrow, then I have to wait for the building inspector to come before I can pour the footings. I'll keep that in mind however, once I go to do the pouring.
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
Driveway Pour Before the Rain.... Hages Building & Construction 1 04-18-2007 07:53 AM
Ripping roof off, rain protection? wease Remodeling 2 12-23-2006 10:08 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
Deck footers not 100% level? ssgumby Building & Construction 1 05-11-2005 08:32 PM
