Did I Screw Up My Cement? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 02:28 PM   #1
Rewards Points: 150
did i screw up my cement?
Hi,
Did 2 patch jobs last night. One dried up and looks ok (one with the gas meter) other looks kinda odd. Did I screw it up? I did run out of cement, and had to add in a different type, the second type had little pebbles init, and the first batch didnt. Let it dry for another couple of days, or rip it out, and start over?
sbmfj is offline   Reply With Quote
Old 10-12-2011, 02:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So what's the problem?
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (10-13-2011)
Old 10-12-2011, 02:59 PM   #3
Rewards Points: 150
second guessing myself I guess. Ill wait a couple more days. Figured if there was a time to rip it out, it may be now, as the cement isnt 100% cured.
Thanks bud!!
Old 10-12-2011, 03:04 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe it's a little ugly but that isn't the end of the world. Use a brick to rub on it a little and see if that purdies it up some.
Old 10-12-2011, 08:07 PM   #5
Civil Engineer
Rewards Points: 4,854
Your post is confusing because you are misusing the term "cement". Cement is a binding agent used to make concrete or mortar. It comes in bags, is powdery, and never has "little rocks" in it. Concrete is a mixture of sand, cement, water and aggregate (aggregate is the rock part). A lot of people refer to concrete as cement, very confusing, and I think that is what you are doing. Possibly you changed from one type of concrete mix to another? Looks OK to me, other than the color difference.
Old 10-13-2011, 09:57 PM   #6
Too Old
It's more then a little ugly But it's doing what you need to be done right? It's a patch and it may need a little work, as long as it will stay in place when it is dry then you are good.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-19-2011, 08:02 AM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
Originally Posted by jennifer20 View Post
Thanks for sharing your information with us but i have no information regarding this.
Then why did you post?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-19-2011, 08:45 AM   #8
Rewards Points: 5,336
She's recovering from a head injury or she thinks this is Facebook.
If you want a list of inane posts, look at her history. It reads like a what's what of ????
Ron
B. Franklin 1759
Old 10-19-2011, 08:53 AM   #9
Rewards Points: 146
I don't think English is her first language, maybe not 2nd or 3rd either.
Old 10-19-2011, 10:15 AM   #10
Concrete & Masonry
Rewards Points: 620
The first one looks like concrete, the second like mortar.......
Either will suffice, it's just easier to use the mortar in most cases.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
sbmfj (10-19-2011)
Lime, type S/N cement and portland zantar Building & Construction 8 07-11-2010 08:53 PM
Putting a gas line in cement slab wskiarea Remodeling 2 03-26-2010 06:59 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
cement stairs scotty123 Building & Construction 1 09-15-2009 12:05 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
