Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-29-2010, 07:00 PM   #1
Did I put circular saw blade on correctly?
just opened. have never put a blade on one before. the directions say teeth up. just wanted to double check. thanks for your help
http://flic.kr/p/8P2vy2
joetab24 is offline   Reply With Quote
Old 10-29-2010, 07:04 PM   #2
nap
You talking to me?
nap's Avatar
looks good.
Old 10-29-2010, 07:43 PM   #3
Household Handyman
Left-hand, battery powered? Too cool. My next skil-type saw will be left-handed for sure.
Old 10-31-2010, 12:45 PM   #4
Hey Joe, that is a question I get a lot at work. My name is Ray and I work at Home Depot in the hardware dept, so Ive seen it all. One thing to check is the spacer behind the blade, if you've got that in the right place, between the motor and the blade , you're ready to rip.
thehammer01 is offline   Reply With Quote
Old 11-01-2010, 05:03 PM   #5
Handyman
Generally, the label on the blade faces the outside. I have a sinking feeling that the saw is not cutting properly. Its not you..its the saw. I own the same saw. I love Ryobi tools but the circ. saw is garbage. Worked fine for a while but now it takes an hour to cut through a popsicle stick! AND it splinters anything you try to cut. The torque is just not there after using it a couple of times even with a fully charged battery.
canadaclub is offline   Reply With Quote
Old 11-10-2010, 02:54 PM   #6
Yes. A good way to remember is the writing (what type of blade it is--Ryobi) is able to read (on the outside)
mreed3426 is offline   Reply With Quote
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
Saw blade rec. for 6-1/2in Circular Saw smoochas Tools 4 06-12-2010 12:21 AM
Best blade for circular saw to cut multiple layers. Clutchcargo Building & Construction 5 12-02-2009 08:27 PM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
