-   -   Did I put circular saw blade on correctly? (http://www.diychatroom.com/f2/did-i-put-circular-saw-blade-correctly-85244/)
joetab24 10-29-2010 06:00 PM
just opened. have never put a blade on one before. the directions say teeth up. just wanted to double check. thanks for your help :no:
http://flic.kr/p/8P2vy2
nap 10-29-2010 06:04 PM
looks good.
Thurman 10-29-2010 06:43 PM
Left-hand, battery powered? Too cool. My next skil-type saw will be left-handed for sure.
thehammer01 10-31-2010 11:45 AM
one more thing
Hey Joe, that is a question I get a lot at work. My name is Ray and I work at Home Depot in the hardware dept, so Ive seen it all. One thing to check is the spacer behind the blade, if you've got that in the right place, between the motor and the blade , you're ready to rip. :thumbsup:
canadaclub 11-01-2010 04:03 PM
Generally, the label on the blade faces the outside. I have a sinking feeling that the saw is not cutting properly. Its not you..its the saw. I own the same saw. I love Ryobi tools but the circ. saw is garbage. Worked fine for a while but now it takes an hour to cut through a popsicle stick! AND it splinters anything you try to cut. The torque is just not there after using it a couple of times even with a fully charged battery.
mreed3426 11-10-2010 01:54 PM
Circular saw blade
Yes. A good way to remember is the writing (what type of blade it is--Ryobi) is able to read (on the outside)
