Deteriorating Basement Wood - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 02:48 PM   #1
The wood slats between the sub floors and joices in the basement are deteriorating. The wood is actually peeling and when the peeled wood is remove the remaining wood underneath is solid. As you can see from the images there is material on the wood surface some is white, some green, and some black stain. I checked for termites and carpenter ants and was told no. Is this some type of mold? The basement is cold and damp in the winter and moisture has come through the cinderblock but I washed and painted over that.
jfl204 is offline   Reply With Quote
Old 02-24-2010, 04:31 PM   #2
Learning by Doing
Leah Frances's Avatar
FYI: Joist
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-24-2010, 05:15 PM   #3
Gee, thanks. You're the best
Old 02-24-2010, 06:11 PM   #4
Civil Engineer
Rewards Points: 4,568
That looks like bark on the board. If so, it is not surprising that it would be peeling, since bark typically comes off after a few years.
Old 02-24-2010, 07:10 PM   #5
Rewards Points: 5,336
This looks like an older house. As previously stated, it looks like bark. Shouldn't be an issue.
Ron
Old 02-27-2010, 05:09 PM   #6
Is that common to find bark in older homes? What's directly above the floor?
jkitchen is offline   Reply With Quote
Wood Stove in Basement? dwolek HVAC 4 10-28-2009 09:02 AM
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 10:55 AM
basement window replacement ponch37300 Building & Construction 3 08-12-2008 04:58 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
