Decking Lights - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 09:10 AM   #1
Decking Lights
I am thinking of installing the decking spot lights. I was just wondering how easy they are to fit, is it pretty straight forward?
I'm thinking of just having 10.
Thanks in advance for any help
rcdltd is offline   Reply With Quote
Old 09-27-2011, 03:46 PM   #2
Rewards Points: 5,336
Easy is relative. Tricky part is running the wires in a concealed manner.
Ron
B. Franklin 1759
Old 09-27-2011, 11:27 PM   #3
Rewards Points: 272
you might want to consider installing these low voltage lights as they don't cast a glaring light into ones eyes and when put at waist height cascade the light onto the deck surface.
http://www.google.ca/imgres?q=low+vo...w=1620&bih=918
fixrite is offline   Reply With Quote
Old 09-28-2011, 01:04 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Well there are many types of lights sold as "deck lighting". The kind that plug into an outlet and are just stakes that you plunge into the ground - I suppose those would be easy to install.
I have 8 LED ones on my deck, 2 flushmounted into each step on the stairs leading up there. I wouldn't say they were super-hard to install, but they weren't easy either. The wiring was the worst part, and then hiding the wiring once it was done.
Of course I created a bit more work for myself by making my own LED kit for $40 instead of paying the $350 ripoff price for a "Kit".
CoconutPete is offline   Reply With Quote
Old 09-29-2011, 11:07 AM   #5
Too Short? Cut it Again!
Take a look at some marine supply catalogs for some low voltage options that might be cheaper than landscape lighting.
Old 09-29-2011, 03:25 PM   #6
Rewards Points: 504
Exactly where mine came from
$3.97 a piece. This does, of course, require a bit more work on your part so if you are not prepared/willing to do that you may be better off spending more money on a "kit".
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Survey on Trex composite decking TC1 Carpentry 22 04-13-2010 02:21 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
