Decking Boards - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 07:47 PM   #1
Decking Boards
Two years ago, I built a deck and placed the boards wrong. Now I noticed they cup. I am totally sick and angry, I did not do my research. It is a huge deck.
Will the cupping continue? What options have I? Could I drill small holes to drain the rain?
This to me is much worse than a "loved one" passing. I'm just so angry at myself.
Please help me with suggestions.
PS=I dare not tell my beloved husband.
Trafoier is offline   Reply With Quote
Old 07-03-2010, 10:26 PM   #2
Rewards Points: 5,336
It would help if you supplied some details.
Type of wood you used?
How the boards were fastened?
Was the deck ever sealed?
Exposure to the Sun
Constantly?
Intermittantly?
You might be able to sand the deck the way you sand floors to remove the cupping.
You might be able to flip them over.
Ron
Old 07-03-2010, 10:34 PM   #3
Registered User
Rewards Points: 526
Meanwhile.......... #9: http://bct.nrc.umass.edu/index.php/p...ns-about-wood/
Be safe, Gary
Old 07-05-2010, 10:47 AM   #4
Reply_Decking Boards
Ron;
The answer to your questions; I used pressure treated decking boards. They were screwed, have sealed it twice and full exposure to sun.
Turning the boards over is not an option, due to the cut-outs of attached posts, including the stain "bloches" under boards. I would have to apply a very dark stain to camouflage. However; I do like your suggestion of "sanding". Hopefully; I can locate a professional??
Trudy
Old 07-05-2010, 11:05 AM   #5
Originally Posted by Trafoier View Post
Ron;
Trudy
There will be an issue with sanding surface mounted fasteners. The screws need to be set lower then the level of the theoretical sanded plane or the screw heads will eat through the sanding paper in a heart beat. A professional would not even attempt this without the screw heads set below the surface.
Another option is to remove each and every board and put it through a planer to remove the cup profile. Then reinstall the boards. So as not to have to put new holes in the boards, you would label each board and put it back in the same location on the deck.
There is no quick and easy fix to this problem, but sanding or planing would be the least expensive.
Ron
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Gate post ledger boards Klawman Building & Construction 5 04-14-2010 01:22 AM
how many decking boards do i need? usc529 Building & Construction 6 02-20-2010 11:54 AM
how to lay my decking boards usc529 Building & Construction 4 02-13-2010 05:08 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
