Deck Steps Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 09:53 AM   #1
Deck Steps Question
My Deck steps are in need of repair
Basically the stringers are cracked in 2 places
I think the support beam on one side of the steps looks as though its come out of concrete
I need to know if this can be short term quick fixed?
If not can someone give me an honest answer as to what it is going to cost me?
stocksy05 is offline   Reply With Quote
Old 04-24-2011, 10:05 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
That cracked stringer is because of the knot.
Short term....jack up the stringer and sister a 2x4 to the inside.
Make it go full length instead of just a scab.
The decking boards can be replaced as well as the post if it's in bad shape.
Good carpenter = 1 day + materials
New stairs = good carpenter @ 3 days + materials
tcleve4911 is offline   Reply With Quote
Old 04-24-2011, 10:12 AM   #3
kwikfishron's Avatar
Rewards Points: 174
kwikfishron is online now   Reply With Quote
Old 04-24-2011, 10:12 AM   #4
Is the quick fix the 1 day + materials?
and the permanent fix 3 days + materials?
Cost?>
Old 04-24-2011, 10:16 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Cost?>
Just a guestimate on time for carpenter. Depends on scope.....
Can't do costs.....not allowed on this forum.....
Old 04-24-2011, 10:17 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Originally Posted by kwikfishron View Post
What??????
Old 04-24-2011, 10:38 AM   #7
ok so my thing is we have the house up for sale, so i dont really want to do anything until we get the inspection or if there is some way we can quck fix to get around the inspection.
The other thing Ive thought of is to delay it until we get an offer and fix it if we get one.
Old 04-24-2011, 10:48 AM   #8
Rewards Points: 266
I would want to have that in good repair if I were showing my house. That's got to be one of the first things a prospective buyer will notice and not a good first impression of the house. It would make me as a buyer wonder what else I will find wrong with the house.
You should ask your real estate agent what is the best way to deal with this. You are paying them for their expertise after all. Unless that is, you are selling it without a real estate agent.
Jim F is offline   Reply With Quote
Old 04-24-2011, 10:49 AM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
..........boy there's always more to the story, huh?
I told you how to repair it.
Fix the stringer yourself.
Do it right away.......
You'll be getting a lot more traffic than usual while people are looking at your house to buy.
All you need is someone falling through that thing during a walk through.
Old 04-24-2011, 02:32 PM   #10
Tizzer's Avatar
Rewards Points: 452
I'm seeing maybe $100 worth of material, w/o seeing the rest of the deck. Looks like (2) 2X12s for stringers,even tossing the treads and replacing with new.
Don't 'rig' it before the inspector comes.
Tizzer is offline   Reply With Quote
Old 04-24-2011, 02:34 PM   #11
Wont the concrete footings need to be refilled now if we are going to put in new stringers?
Old 04-24-2011, 04:38 PM   #12
Registered User
Rewards Points: 5,204
Yes, and new bearing blocks under the side stringers with the posts for the guard-rails and handrail.
Also need; 3 stringers, not 2;
closed risers unless 4" under;
stringer /joist metal tie support on correct side of beam;
additional posts if cut stringer span more than 6', 7' for S.P.;
lowered guard-rails so 6" sphere unable;
figs. 27-34 here; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
May as well bring it up to today's Code as that stringer is fully compromised, do not suggest a "band-aid" sister.
Gary
Old 04-24-2011, 07:25 PM   #13
Replace it completely, should take about a day if you know what you are doing.
Hatsee is offline   Reply With Quote
Old 04-25-2011, 09:53 PM   #14
Will be a lot cheaper to pay a good carpenter to redo it, than when someone looking at your place tumbles when the stairs buckle and shatters their ankle...
besides, you can bring in someone for a day to put a bandaid on it,
or bring in a guy for a day or two to rebuild the stairs and take care of whatever other issues, cheaper just to get it done initially. Nice new steps will add value too, add some fancy lights while u are at it.
chrisBC is offline   Reply With Quote
Question about refinishing a deck... Ler0y Jenkins General DIY Discussions 11 05-26-2010 10:09 AM
deck question toddj99 General DIY Discussions 5 04-24-2010 11:12 PM
Ipe deck + clip question saskman72 Building & Construction 2 07-30-2009 04:03 PM
Deck beam splice question drtbk4ever Building & Construction 8 07-22-2009 08:00 PM
Two Story Deck Question Chris11 Building & Construction 4 05-06-2009 11:34 AM
