Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-14-2009, 05:29 PM   #1
Deck rail Question
Does the wood in the pictures below need to be replaced or can it be rescued and sealed? The rest of the deck is in good shape. I think a good power wash and sealer will make it look nice.
Jim
Deck rail Question-im002532.jpg   Deck rail Question-im002533.jpg   Deck rail Question-im002534.jpg
Speckert is offline   Reply With Quote
Old 03-14-2009, 06:31 PM   #2
Remodeling Contractor
Deck rail Question
needs to be replaced since sealer was not applied as often as needed.
Old 03-14-2009, 08:29 PM   #3
Drywall contractor
Deck rail Question
Sealer won't do much for the splits and cracks in the 2"x6" on top of the rail at this point. If the railing itself is still solid, you might get another year or two out of it by washing and sealing, but it won't "turn back the clock". The damage is done. You could possibly just replace the 2"x6". Hard to tell from the picture about the actual decking, but the step treads are getting a little "iffy". They don't appear to be as bad as the top cap on the rail though.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-15-2009, 01:17 AM   #4
Moderator
Termite's Avatar
Deck rail Question
Yeah, that wood is shot. Time to replace it.
Old 03-16-2009, 12:46 PM   #5
Deck rail Question
Thanks for the input guys.
The rail and the stairs are going to get replaced. It looks like they sealed everything else - including the aluminum siding in places. After I replace the bad wood - everything will get power washed and sealed.
Thanks Again
jim
Question about maximum deck size in Delaware. Doctorsti Building & Construction 13 03-03-2009 08:21 PM
Pergola over Deck Question figgyb44 Building & Construction 2 06-10-2008 08:50 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
