#1 |
Deck question.
Building a deck 35' x 12' off the back of the house. Have a double beam made of 2x12 over 6 6x6 posts. Health department wants last 2 moved cause it's too close to the septic. Now I need to make another beam supported by 2 6x6 posts. Tank is at the corner of the house at 10 feet out. Footings have to be 5' from the tank. How far over the posts can I run my beam? I'm thinking I can have 2 sections.
1@ 19'x12' and the other 16'x7'. My main beam is 10' out and my last post is at 16'. Can I run 3' over the post and tie in to the other beam that's 5' from the house with my joists? I want the most decking I can get. Last edited by Keithdeck; 12-02-2011 at 09:20 PM. |
#2 |
old guy contractor
Deck question.
I think we'll need to see a rough drawing of this one....
#3 |
Disabled wood vet
Deck question.
Yes. 3' is fine, ss long as that beam carries back to at least the 3rd post from the cantilever (14' before the cant I'm assuming). Basically, you will end up with a 12 x 35 deck with a 16x5' section taken out, right?
#4 |
Deck question.
35' is an odd ball length so there's going to be a lot of waste of lumber.
Something devisable by nominal lumber lenghts would make more since. |
#5 |
Disabled wood vet
Deck question. |
| The Following User Says Thank You to titanoman For This Useful Post: | Willie T (12-03-2011) |
#6 |
Residential Designer
Deck question.
Where are you located that you don't need a proper design and plans before getting permits?
Andy. |
#7 | |
Military Mom of 4
Deck question.Quote:
My town: no permit necessary for my deck. . . .which I found out after I actually drew up proper schematics for the sucker.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
#8 |
Disabled wood vet
Deck question.
After seeing your pictures (which I already had in my head), I say it again: 3' is fine.
#9 | |
Disabled wood vet
Not only did you not need permits for the monster decks, but not even the houses! I framed everything like I was still building in California, so the whole subdivision would pass any inspections out here. It just amazing how different building can be from one area to the next. But anything that can be seen from the road, I'm going to find out what the requirements are before I start digging anything. |
| The Following User Says Thank You to titanoman For This Useful Post: | Snav (12-03-2011) |
#10 |
Deck question.
Titanoman, as someone who has suspended decks 40' in the air, would you be able to comment on my question about deck posts?:
Long deck poles Many thanks, Okie (sorry but I cannot send private messages yet--too new to the forum) |
| Display Modes | |
| Cold Deck flat roof and insulation question... | paredown | Roofing/Siding | 16 | 05-15-2012 06:11 PM |
| 16 x 20 deck question | canyonbc | Carpentry | 9 | 01-12-2010 09:01 PM |
| Question about Supporting My Deck. . . | bochamps | Building & Construction | 12 | 05-30-2009 08:57 PM |
| Building a deck - another project for later this summer (Question re: materials) | DyerWolf | Carpentry | 8 | 05-07-2009 02:41 PM |
| Help - Question on deck rebuild? | missin44 | Building & Construction | 9 | 08-22-2008 12:21 PM |
