Deck Development Regulations Translation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 09:27 PM   #1
Newbie Bill
Rewards Points: 518
Deck development regulations translation
Hey Gang,
I am going to be replacing my deck, see the thread in the Project Showcase.
Deck repair, oops replace, oops new patio door thread
I need some help interpreting my counties deck development regulations below.
Development regulations
Decks greater than 0.6 m (2.0 ft.) in height may project up to:
- 0.6m (2 ft.) into a required yard less than 4.0 m (13.1 ft.)
- 2.0 m (6.6 ft.) into a required yard of between 4.0 m (13.1 ft.) and 7.4 m (24.3 ft.)
- 3.5 m (11.6 ft.) into a required yard of greater than 7.4 m (24.3 ft.)
Am I correct in assuming that the maximum distance a deck can project out is 11.6 ft, if my yard is at least 24.3 feet?
That's seems kind of small, especially since the existing deck is/was 12.1 ft.
Any thoughts appreciated.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 07-12-2009, 07:16 AM   #2
That's how I read it, but the old deck was a non-conforming deck. Probably built before the latest code, which was arbitrarily set to trap those of you with larger decks.
There is no rhyme/reason behind some regulations. They are often difficult or impossible to change once in place, and often have no useful purpose. But it is what the powers to be deemed necessary for your good life. Think of that next election time.
Old 07-12-2009, 08:42 AM   #3
Rewards Points: 5,336
These setback regulations can sometimes be adjusted by applying for a variance. In NYC, the setback from the rear property line is 30 feet, but can easily be adjusted down to 24' by a simple request.
Check out your building dept. to see if yours is able to be modified.
Ron
Old 07-12-2009, 09:26 AM   #4
Newbie Bill
Rewards Points: 518
OK, Thanks guys.
I'll be giving the planning department a call tomorrow.
Bill
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Extend House Roof Over Back Deck Justahome Carpentry 1 04-03-2009 08:25 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
