Deck Confusion - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 10:08 AM   #1
Deck Confusion
I would appreciate some advice on my deck. I had my deck redone with "one time" stain last fall. The company sanded and power washed the deck then applied the material. We had a rainfall 4 or 5 hours after it went on. It looked decent (color and coverage) before winter came. The major downside was that the knots in the wood were lighter than the planks and that the powerwash roughed up the wood so that after the stain went on there were still fuzzy areas. This spring the deck color has faded some and the fuzzy areas are still there.
I had the deck company come by last fall and this month and they said the following:
  • In general that the product looked good
  • that the fuzzy areas were a minor flaw resulting from insufficient sanding and that they would weather off.
  • The knots will not accept stain as readily as the planks
I don't know much about deck treatment. Am I being handed a line by the company or does this seem like decent info. Hoping more seasoned deck hands could give me some insight.
Viking2008 is offline   Reply With Quote
Old 07-08-2008, 03:14 PM   #2
Registered User
Termite's Avatar
Knots are pretty stain-resistant. I'd buy that part.
As for the fuzz, that's a copout. The fuzz is from the power washing, and insufficient sanding to remove the raised grain. They should take care of that.
As for "one time" or "lifetime" deck staining and sealing, I think it is a load of hogwash. I've seen a lot of people advertise it but have yet to see an application hold up much better than conventional DIY stain/sealer.
Old 07-08-2008, 04:57 PM   #3
Yep! He is however, right about the knots.
Cajun1 is offline   Reply With Quote
Old 07-10-2008, 02:54 PM   #4
Deck Staining Pro
bigchaz's Avatar
Your main problem was buying the snake oil "one time" deck stain. Fuzzies are from the use of too much pressure on the wood when cleaning
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 07-10-2008, 03:41 PM   #5
Licensed Contractor
Knots will not absorb stain as readily as the rest of the deck.
When I am restaining a deck, I'll powerwash it (being careful not to damage the wood), let it dry completely, then power sand the entire horizontal surface using either a floor drum sander, or a random orbital sander to remove as much as the old finish as possible, and prep the surface for accepting the new finish.
Because of the labor involved, and the chance of finish failing (PT decks with their multitude of cracks are prone to failure) I rarely do this anymore. I recently turned down refinishing a 1500sf deck because the reality was, it needed to be replaced, and callbacks were a certainty.
If the deck co is reasonable, they MIGHT come out and sand and top the deck off with another coat.
If not, what-you-see-is-what-you-get.
Renovator,LLC is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
