Decal On Varnished Wood - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 09:53 AM   #1
decal on varnished wood
I have a varnished box with a decal on top. Anyone know how to remove the decal without harm to the varnish?
Don T. is offline   Reply With Quote
Old 09-23-2009, 11:16 AM   #2
I removed a decal from a bureau using a very small amount of water to get the decal wet
This method may depend upon what the decal is made from
I think mine was "paper" based
Old 09-23-2009, 12:15 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
WD-40
But I'd try a dab on bottom or the back of the box, because while WD-40 is normally not that aggressive it contains 50% hexane (similar to kerosene)
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-23-2009, 12:28 PM   #4
Drywall contractor
Rewards Points: 1,070
Goof-off?? Again, test it on an inconspicuous place first....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-25-2009, 04:17 PM   #5
Rewards Points: 5,336
If the decal is under the varnish, you would have to dissolve the varnish to get to the decal.
Ron
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
