Dampness - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 09:29 AM   #1
dampness
why do i get dampness on my windows and walls even when i leave the window open a bit and the door open
And who is the right person to correct this problem ?
keef is offline   Reply With Quote
Old 11-15-2011, 10:22 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
The moisture in the air is condensing on the windows and walls.
Right person to correct the problem? You. Close the windows and doors.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
gregzoll (11-15-2011), keef (11-15-2011)
Old 11-15-2011, 11:43 AM   #3
amyevans's Avatar
I think the OP was implying that they get the dampness all the time and while they would expect it to go when opening windows and doors, it doesn't.
I think, anyway...
amyevans is offline   Reply With Quote
Old 11-15-2011, 05:53 PM   #4
Rewards Points: 5,336
You will need to figure out the problem why?
You need to know a few things to do this.
1. Humidity levels inside the house.
-Buy a cheap hygrometer to measure the levels.
2. What's causing the high levels?
-Whats adding to the levels in the house?
-Bathroom humidity?
-Kitchen humidity from cooking?
-Malfunctioning furnace humidifier?
-High basement humidity?
-Leak somewhere in the house
Each reason will have a remedy, but you need to determine the cause.
Is this a new issue?
How long have you lived there?
Ron
B. Franklin 1759
Pool lanai gutter overflowing and soffit dampness Limeybstrd Roofing/Siding 1 08-31-2011 12:03 AM
Dampness in wall next to bathtub frankieo Plumbing 2 01-07-2009 05:26 PM
Dampness with mold need help! 68MHJCs Building & Construction 7 08-12-2008 01:21 PM
Tuckpointing to fix basement dampness (with pics)? WhammyRose Remodeling 6 01-31-2008 02:55 PM
damp basement wall. itguru Building & Construction 7 12-16-2007 06:02 PM
