Damaged Riser - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 05:42 PM   #1
Damaged riser
I recently removed carpeting from my stairs and found the riser inrough shape. It's a thin stripthat is splitand loose to the touch. Any easy repair ideas? Can I glue it or just replace it?
If replacing, how do I access the riser?
somuchjackson is offline   Reply With Quote
Old 07-19-2011, 05:44 PM   #2
DIY staff
Rewards Points: 7,174
What are you going to do?
Recarpet or restore the stairs.
Old 07-19-2011, 05:56 PM   #3
Right, good clarifier. I will be refinishing the treads and painting the risers white.
Old 07-19-2011, 06:43 PM   #4
DIY staff
You have nothing to loose by trying to repair that----plan on some putty--after you glue dries.
For a painted repair,I suggest Durhams water putty or Plastic Wood---Both ar very hard and will take some abuse.
If that curved piece needs replacing look to a millwork shop that sells stair parts.
That is 'bending' plywood----3/4" ply with a saw cut every 1/8" or so on the back going almost to the face.
Old 07-19-2011, 06:54 PM   #5
Rewards Points: 6,652
Post progress pictures & finished, in the showcase forum. Will love to see how they turn out.
Old 07-19-2011, 07:19 PM   #6
Rewards Points: 558
Or he can glue and sand as suggested and then apply a wood veneer over existing riser paint or stain to match…
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Ron6519 (07-20-2011)
Old 07-19-2011, 08:56 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
1/8 inch Baltic Birch will bend with the grain and usually comes in 5'X5' sheets. The big box stores usually won't have it but a cabinet supply will.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-19-2011, 10:55 PM   #8
Many thanks for all of your replies.
You're right that I have nothing to lose by attempting a glue type repair. If I'm not happy with the results I'll try what some of the others have suggested.
Will post pictures when I get to this project (just bought our first house - a 1920's craftman that needs to be painted head to toe - so it's a wee bit down on the punchlist!)
Old 07-19-2011, 11:13 PM   #9
In that case, since you just bought, and looking for ideas, post pictures away. Especially outside. Craftsman's if kept in original style, will recoup their value, when you restore and maintain. How is the mechanicals (hvac, water heater, plumbing), windows, doors, and electric? Also keep in mind, is when you do anything regarding computer networking & a/v, is how it blends into the style of the home, and will fit it when it comes time to sell.
Have fun and enjoy. We have a 1937 bungalow, and currently still working on a Kitchen remodel. Already have done a Bath remodel, which if you want pic's, I can post for you, so that you can get an idea how to blend modern, into a period home.
How do I remove part of the damaged subfloor? ChEMom Flooring 17 07-15-2011 12:28 PM
Extracting a broken sprinkler riser? SinCitySteve Landscaping & Lawn Care 4 09-05-2010 03:51 PM
Replacing Termite Damaged Sill, Joists, and Girders bd_dc Building & Construction 0 02-01-2010 11:21 PM
Damaged fascia (Pics) timcsi Roofing/Siding 7 09-15-2009 10:00 AM
How to Repair Spot Damaged Carpet jrguy Flooring 1 08-25-2009 06:45 AM
