Damaged Marble Beyond Repair? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-25-2007, 11:44 AM   #1
Exclamation
Damaged marble beyond repair?
I'm trying to figure out if the damage done during the installation of my marble slab warrants replacement of the slab, or if it is fixable.
It looks like the damage was done when they drilled the holes for the faucets. One of the holes is really thin, like it might break when we tighten the faucet to the slab. Also, I don't have (or want) the plate type faucets that would cover it. I specifically ordered the faucet to not have a plate under it.
The fabricator also screwed up with the edge. I was supposed to have a demi-bullnose with a laminated edge offset under it (which I am paying more for), but they didn't do the offset like they said they would.
Below is a picture of the damage that was done around the faucet holes.
What is your opinion...fixable, or have them give me a new slab?
argana is offline   Reply With Quote
Old 10-25-2007, 01:51 PM   #2
Will your fixture cover that area of chip-out completely? If not, I'd certainly tell them that it's unacceptable. Were there samples in their showroom with holes drilled? You can point to those displays as the expected level of workmanship.
NateHanson is offline   Reply With Quote
Old 10-26-2007, 10:47 PM   #3
Rewards Points: 5,336
Tell them to take it back. They cut the holes from the back causing blow out on the finished surface. Wrong edge profile too? Get a refund and go somewhere else, these guys are incompetant.
Ron
Old 10-29-2007, 09:15 PM   #4
remodeling pro
Even though the faucet base will most likely cover those pitiful holes, I would always have such poor workmanship in my mind. If they put the wrong edge treatment, the holes are a moot point, because you have every right to expect the top to be replaced with what you ordered, and be sure to mention that such workmanship is not expected on a top end product.
troubleseeker is offline   Reply With Quote
Old 10-30-2007, 09:57 PM   #5
Why the three holes if you were going to install a faucet without the plate? Looks to be an 8" spread. You would only need one hole.
Ron
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 06:37 AM
"grease pencil" on marble tiles! zel Flooring 7 04-29-2008 05:22 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 12:27 PM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 09:46 AM
