-   -   Damaged aluminum siding (http://www.diychatroom.com/f2/damaged-aluminum-siding-107929/)
MosbyB 06-17-2011 02:03 PM
We recently had our siding pressure washed, and now some of the siding seems to be coming away from the house. Is it possible to just nail the siding back in place? What should we do? Any advice would be appreciated. Thanks!
M
Ron6519 06-17-2011 03:34 PM
M
As long as the exposed facings are not damaged, you can renail it. The issue is getting it overlapped again without damaging the parts.
Can you post a photo?
Just Bill 06-18-2011 06:14 AM
The way siding works, the bottom snaps into the piece under it and the top is nailed. The nails are covered by the next piece above it. I am guessing the pieces have come unsnapped. You can usually get them to snap back together by gently forcing the piece over the locking edge on the piece below. There is a simple tool called a zip tool that can assist this, available at homes stores that sell siding.
Ron6519 06-19-2011 02:01 PM
Bill, will the zip tool work on aluminum siding? Is there enough give in aluminum?
rossfingal 06-20-2011 10:19 AM
The "zip" tools prevalent today ("Sideswiper II" by "Malco"), that are available
in Big Box stores and siding supply stores; are really intended for Vinyl
siding.
I used to have "zip" tools for aluminum siding - the difference between the
two is the thickness of the hooked metal - the old ones were "spring" steel -
thinner then the ones out there now.
We used to put wax or oil on them - they would slide easier.
Using them on aluminum was usually a two person job and we used 3 or
4 "zip" tools - aluminum doesn't flex the way Vinyl does.
How difficult it will be, also depends on the thickness of the aluminum -
.019, .024, etc...
rossfingal
Tom Struble 06-20-2011 07:14 PM
the loose siding may not even be unhooked,it may just be last course or something,op never said:(
