Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-25-2013, 12:28 AM   #1
cutting wood flooring by toekick
Ugh. My uncle is wanting to chnage flooring. Doesn't want to pull cabinets.
So wondering if anyone has tips on cutting beside the toekick?
Have used Sawzall and chisel in the past.
Can use a Rockwell oscillating saw, but seems like it would be real slow.
mae-ling is offline   Reply With Quote
Old 01-25-2013, 01:20 AM   #2
Use A Toe Kick Saw. That's that there made for.
http://www.craintools.com/pages/more.../795_more.html
Home Depot rent them or you can buy a cheap copy from Northern Tool.
Old 01-25-2013, 08:33 AM   #3
Super Moderator
The toe kick saw is really dangerous----scary dangerous--so be in your guard---
What's there now? Often I will remove the old toe kicks to allow a more brutal method of removing the old floor covering--then rip some nice new ones---
you know the old ones look tired and worn by the time the floor need replacing---
oh'mike is online now   Reply With Quote
Old 01-25-2013, 10:25 AM   #4
"Nail-Bender"
Yeah -
Watch out with a "toe-kick" saw!
Nasty, "kick-back"!
If you do use one - saw the floor in front of the cabinets, first.
Better to just replace the kick-boards, too -
You can still use a "toe-kick" saw - you'll have more room to "fudge" -
if you pull the toe-kicks out.
"RF"
rossfingal is offline   Reply With Quote
Old 01-25-2013, 12:12 PM   #5
STAFF
BigJim's Avatar
I don't understand why they haven't put a kickback cleat on that saw yet, it could keep it from a nasty kickback.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (01-25-2013)
Old 01-26-2013, 12:16 AM   #6
The toe kick is only 1/4" thick.
No tool rental here, nearest is almost 3 hrs away, may need to do trip.
Flooring piece that needs cut goes about 2" under cabinets (2.5" pieces) then carries on under as far as I know, tongue with nails is under cabinet. Maybe I could slip a sawzall blade under the flooring and cut the nails then pull the piece out.
Ripping about 14' and cross cutting about 6', the cross cutting is on the ends of the cabinets and could be done with a sawzall.
Old 01-26-2013, 12:21 AM   #7
Super Moderator
I think you will be using the saws all on most of that----if you pull the toe kicks I think it will go faster-------
Old 01-26-2013, 01:11 AM   #8
Toe kick is only 1/4" will pull it but can't see it help much. wood still 1.75" under. These are not your standard cabinet build.
The Following User Says Thank You to mae-ling For This Useful Post:
oh'mike (01-26-2013)
Old 01-26-2013, 05:53 AM   #9
Super Moderator
As usual---You will have to figure it out as you go along--
mae-ling (01-26-2013)
recommendations for cutting shallow grooves in narrow wood strips wengang1 Carpentry 17 08-03-2012 11:54 AM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 03:22 PM
wood cutting 4-1/2" grinder blades amakarevic Carpentry 28 12-16-2011 07:35 PM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 07:50 PM
Old wood flooring - leaks from second floor p<0.05 Flooring 7 05-20-2009 05:41 AM
