Cutting Shingles To Install Gutters - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-13-2004, 06:52 PM   #1
cutting shingles to install gutters
I need to install gutters along one side of my garage. However, when the garage was last shingled (before I moved in), the shingles were wrapped around the edge of the roof where the gutters would hang.
I believe I need to trim back the shingles to install the gutters. What is the best technique for this? Also, should I install flashing before the gutters go up, and how is that done?
I've installed gutters before, but I've never encountered shingles wrapped around the edge of the roof line.
Chicago Bill is offline   Reply With Quote
Old 02-27-2009, 02:02 AM   #2
this is a peculiar way to provide a drip edge, wrapping it downward onto the fascia.
On a warm day, preferably, cut as straight as a line as you can, about 3/8" out from the roof deck, so it hangs out past the deck, then put in a galvanized dip edge and slip it up under the roofing material. You may also have to cement it in, unles you can get a small roofing nail through the metal into the deck, UNDER the roof underlayment, or "paper". depending on how brittle the comp shingles have become with age, it may be a hard job to do well.
allencd@cox.net is offline   Reply With Quote
Old 02-27-2009, 06:42 AM   #3
SDC
SDC's Avatar
Something tell me the op will not see the post you made, it's only 4 1/2 years old
SDC is offline   Reply With Quote
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 06:53 AM
leaf free gutters icicles and ice dams bluemetro Roofing/Siding 16 02-23-2010 10:14 AM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 09:57 AM
Cutting shingles on the eve xray328 Roofing/Siding 16 04-15-2007 05:54 AM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 09:13 PM
