Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-15-2007, 03:33 PM   #1
Cutting Marble Countertop
My husband needs your help - he is insistant on trying to cut a piece of marble that is 62" x 32" to make it into a double sink on his own but doesn't have the knowledge to do it.
Can anyone tell me if he can in fact do this himself and if so how. i.e. which saw and blade that would not cost his arm and leg?
Thanks - The Wife....
Gina Crisci is offline   Reply With Quote
Old 10-15-2007, 03:58 PM   #2
At any large home center or hardware store, you can buy a diamond blade that will cut the marble. You can get one to fit whatever tool he has to cut with...either an angle grinder or a 7&a quarter inch circular saw. You can put the right blade on either of these tools and cut the marble. Make sure to drizzle water on the blade while cutting to help keep it cool. The key word here is drizzle...not drench. A spray bottle on the stream setting would work. Take care not to wet the motor of the saw.
You mentioned that it was going to be a dual sink vanity top? Hopefully you plan on using drop-in sinks and not undermount. The undermounts require a clean cut and a polished edge...not a diy job. If using drop-ins, you still have to make a decent cut so the sink fits with no gaps showing around the perimiter of the flange...it is do-able though.
send_it_all is offline   Reply With Quote
Old 10-15-2007, 04:01 PM   #3
Also...I would suggest doing this on a flat surface on three, level sawhorses..probably with a sheet of plywood underneath the marble to support it. when the sinks are cut out there wont be much material remaining to hold it together....This can be done, but it takes time and care...good luck.
Old 10-15-2007, 04:17 PM   #4
even professional can cut the marble and the marble just break... not to blame the your husband for that if this happen... because the piece may have crack internally.... If I have to do it... rather than dry cutting... I will use a wet saw.... to reduce heat ...etc....
if the marble can be ordered pre-cutted , it is the best... but I assume it will be much more expensive, as the manufacturer will absorb the cost of the broken piece if it ever broken....
so does it costs real cheap for you to get this raw material piece so that you have to do it that way....i.e how much exactly does this cost you...
KUIPORNG is offline   Reply With Quote
Old 10-15-2007, 04:28 PM   #5
We are taking a french buffet and converting it to a two sink vanity. The marble is already fitted to the buffet.
Old 10-15-2007, 10:57 PM   #6
Kyle Emerick
kemerick's Avatar
Fitted? It has been cut to size but is not mounted?
Get some helpers and get it outside on a strong and stable surface to cut it on. 2x4's spaced a few inches apart across the whole bottom sounds good.
As said before the edge does not have to be great if using self-rimming sinks. Mine looks like I cut it with a sledge hammer but once the sink is in it will wide the wild line. The bottom line is you need enough left over so it can still hold the sink but not enough removed so there is a gap.
I say get it outside, get it stable and cut it with a grinder or recripcating saw. You can get a cheap masonry blade and it will do the trick as it is what I used to trim out my sink after I cut the tiles with a wet saw:
http://www.emerickdesigns.com/media/...8/target4.html
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest.
You can see many galleries of it located here under Galleries and then House.
kemerick is offline   Reply With Quote
More On This Topic
Hi on behalf of Expert Village my name is Andrea Spano and I'm going to show you how to make several different flavored cheesecakes but one basic cheesecake recipe from my new book Not Just Desserts. So as I said we're going to take a basic cheesecake... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be showing you how to install a cutting blade for a chop saw. After your old blade has been removed, you want to install your new blade. Now make sure that you are buying the... Read More »
So in this clip I'd like to show you how to do what's called feather marbling. So feather marbling is a very messy technique. So what we're going to do, and normally you would try this over a sink, but today I just sort of put out some paper towels for... Read More »
Okay let's start with our piece of meat which is this. The nice thing about Korean barbecue making a marinade is that you don't necessarily have to use the highest cut of beef. This is a beef chuck steak and I'm going to take it out and put it in our... Read More »
Hi on behalf of Expert Village my name is Andrea Spano and I'm going to show you how to make several different flavored cheesecakes but one basic cheesecake recipe from my new book Not Just Desserts. So let me drizzle it a little bit more you can get... Read More »
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 01:27 PM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 05:39 AM
Marble Tile Countertop? Sportbilly Remodeling 14 05-17-2007 01:01 AM
Formica countertop cutting mekanic Carpentry 3 11-01-2006 08:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
