Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-07-2011, 01:45 PM   #1
Cutting Granite
Hey guys,
So i have a project underway where I will need to cut 1.25" thick granite.
The slabs are about 21x21 inches and I will be cutting 7-8" width slabs
I went to Home Depot and they have the following saws, and I was just wondering which saw would be best for the job
They have
Diamond MK101
Dewald D2400
Pearl Abrasive VXXL2 Pro Tile Saw
The guy recommended the Pearl Abrasive because he knew how to change the blade on that one to a diamond one but he wasn't sure if it's possible to change the other ones
Thanks!
indep is offline   Reply With Quote
Old 04-07-2011, 03:37 PM   #2
Cutting Granite
Just go to each companies website and see what the specs are for each saw. Cutting that thickness of granite will require a saw with some gusto.
If this is a one time usage, you might want to rent a heavy duty saw just for this job. Most cutting jobs don't need the power that cutting through granite rerquires.
Ron
Old 04-07-2011, 09:50 PM   #3
Tileguy
Bud Cline's Avatar
Cutting Granite
All of those saws use diamond blades.
You should be able to rent a "stone saw" at a tool rental. A stone saw will have the heft and horsepower to cut granite that thick.
Old 04-07-2011, 10:58 PM   #4
Cutting Granite
hey,
those were all the saws he had... isn't diamond blade good enough?
can you guys point me to some saw models or types/specs that I should look for when I go to other shops (this was at hd by thew ay but there are other shops here as well)
thanks
I also wanted to ask, when I cut the slabs, will the edges be super sharp or will it be fine?
Old 04-08-2011, 03:56 PM   #5
Cutting Granite
Originally Posted by indep View Post
hey,
thanks
If you'll be cutting this type and thickness material on a regular basis, you'll need a commercial saw. If not, you'll still need a heavy duty saw to get through granite 1 1/2" thick.
I don't know what this means:
"when I cut the slabs, will the edges be super sharp or will it be fine?"
The cut will be rough with minor chip out at the top.
Ron
Old 04-09-2011, 11:54 AM   #6
Cutting Granite
iam a stone fabricator. in a pinch, i have used a makita worm drive saw or circular saw. buy a quality 7" diamond blade to put on it. purchase a straight edge from HD about 3-4ft long. it should have a small lip on one end for saw to ride against. clamp straight edge to stone after precise measurements. have a helper mist stone with water hose to minimize dust. PURCHASE A PORTABLE GFI to plug saw into! CUT NICE AND SLOW!
acglobal is offline   Reply With Quote
The Following User Says Thank You to acglobal For This Useful Post:
Thurman (04-11-2011)
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 11:08 PM
Cutting granite farmerde Flooring 15 02-11-2010 12:13 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Anyone experienced cutting granite? Bigman610 Remodeling 4 05-04-2007 02:16 PM
granite counter top cutting trifit1 Remodeling 2 02-12-2006 07:56 PM
