#1 |
Cutting glass tile?
I have a situation where I have to make a single gang box into a two gang box. The tile back splash is small square glass. I have a very good dremal. Any idea if that will work? And if so what kinda bit should I get?
#2 |
Small Business Owner
Cutting glass tile?
If the tile is small enough.....could you cut along the grout lines and still cover the cut with the plate? The grout is relatively easy to cut compared to the tile itself.
#3 |
Cutting glass tile?
I don't think I can I am going to try but I think its going to end up in tile
#4 |
Cutting glass tile?
I've no experiance will glass tile, but ceramic tile is hard stuff and requires a diamond blade to cut along with a tile saw. You might need to try several different blades on the Dremel before finding one that works.
#5 |
Remodeling Contractor
Cutting glass tile?
Glass tiles will chip using the diamond blades made for ceramics. Glass diamond blades use small diamonds and a denser spread. You can cut the tile, but it will leave chips along the edge. But as posted above the electrical cover plate will cover this.
#6 |
Cutting glass tile?
I've used this one a lot. On glass, as Bob mentions above, it will flake the edges but it's probably your best bet.
http://www.dremel.com/en-us/Attachme...rial=Porcelain |
#7 |
Cutting glass tile?
Thank you I will get those bits :-) and if it chips a little bit the plate should cover
#8 |
Cutting glass tile?
Just cut very slowly. Also, if needed you can buy oversized plates at an electrical supply store.
| Display Modes | |
| "Defogging" double-pane windows .... a gimmick?? | alexz | General Discussion | 133 | 03-10-2010 01:35 PM |
| Cutting Narrow Tile Pieces | MrBill_DIY | Remodeling | 2 | 08-17-2008 01:33 AM |
| removing glass 4x4 tile | tilewoes | Building & Construction | 1 | 06-10-2008 10:54 PM |
| Problem Glass Tile Shower | robin2107 | Remodeling | 9 | 04-23-2007 09:19 PM |
