Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-15-2010, 09:20 PM   #1
Cutting a glass mirror
I just put tile on the walls in my bathroom. There was a large mirror in the bathroom. I want to put that mirror back where it was. Only problem is it's about 11 inches too long. A friend told me that you can get a mirror cut. Is that true? Could I do it myself?
phil74501 is offline   Reply With Quote
Old 10-15-2010, 09:53 PM   #2
You can cut it yourself, but you would also have to sand the edge down so it isnt razor sharp. I would bring it somewhere (your local glass shop) to have it cut if possible.
Here is a simple instruction:
http://www.youtube.com/watch?v=4EdTH...eature=related
If you do try it yourself make sure you wear leather gloves when snapping it (you probably wont be able to snap it like the video shows your first time, especially since your mirror is probably 1/4" thick).
BE CAREFUL, glass is no joke and will easily cut you to your bone in a split second before you even know what happened.
jegolopolli is offline   Reply With Quote
Old 10-15-2010, 09:55 PM   #3
How much does it cost to have a glass company cut it?
Old 10-15-2010, 10:07 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
You need to call around, since everyone's town has different companies that quote different prices. No way of knowing, until you do the 411.
Old 10-15-2010, 10:31 PM   #5
Ok, thanks for the info.
Cutting glass jjrbus Building & Construction 9 12-06-2009 08:29 PM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 10:02 AM
Cutting glass tile? dSilanskas General Discussion 7 03-30-2009 06:56 AM
cutting glass victor General Discussion 2 08-07-2007 12:51 AM
crack in glass mirror rookie50 Building & Construction 3 12-04-2006 08:55 PM
