Cutting Flourescent Lens Covers - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 11:07 PM   #1
cutting flourescent lens covers
I purchased acrylic flourescent lens covers from Home Depot however, they don't fit and will need to be cut. How do I cut them ?
Brandner is offline   Reply With Quote
Old 04-12-2012, 11:15 PM   #2
Rewards Points: 1,092
Not easily. I've tried, and have had limited success: taping them and cutting them w/ a plywood saw blade (oodles of small teeth); have tried scoring them w/ a sharp utility knife, then snapping them; have had some success filing the &^%($ing things. If I ever have to shorten another one of those brittle and weak objects, I think I will heat a thin piece of iron w/ my torch and melt my way through. I hope someone posts something that works.
Old 04-12-2012, 11:26 PM   #3
Rewards Points: 14,306
Ossilating saw would cut it without melting it or cracking it.
Old 04-12-2012, 11:30 PM   #4
joe: ok. will try that next time. thanks.
Old 04-13-2012, 12:22 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Use 'Scoring Knife Blades' in your Utility knife.
Works great for me.
http://www.stanleytools.com/default....ng+Knife+Blade
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-13-2012, 01:00 AM   #6
bob: cool. another vote for switch blades. i'll try one of these muthas. my "typical" utility knife was not giving consistent breaks, but maybe that was my technique: swearing and being in a hurry.
Old 04-13-2012, 01:36 AM   #7
Tool Geek
PaliBob's Avatar
I put some heavy cardboard on the floor first.
Use some kind of a strait edge.
Cut slightly less than perfect. It's hell trying to trim off an eighth inch.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-13-2012, 03:54 PM   #8
jschaben
Rewards Points: 502
I happen to have a fine tooth flush trim pull saw. Does a nice job but a bit slower. Band saw works well if you have enough throat capacity. Nix on a jig saw, reciprocating action just tears it up.... don't ask how I know that
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 04-13-2012, 06:29 PM   #9
Rewards Points: 2,212
zip disc (or any thin disc) in a grinder
mae-ling is offline   Reply With Quote
Old 04-13-2012, 07:30 PM   #10
Tool Geek
PaliBob's Avatar
These are 24"x 48" panels that come in a pack of five, so at ~$10 each the OP wants to cut them to size with as little fuss as possible.
His Acrylic panels are most likely similar to thes:
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-13-2012, 07:36 PM   #11
Pure Genius
Rewards Points: 150
I always flip the blade on my tablesaw and cut away. Works like a charm.
Dierte is offline   Reply With Quote
Old 04-13-2012, 08:00 PM   #12
jschaben
Rewards Points: 502
Ooops, I thought you were talking about the eggcrate style. I cut it like regular acrylic. Most will disagree but I have the best luck just scoring it on the table saw. Usually score one side, flip and score the other. If it already hasn't seperated it will just snap with a clean edge on both pieces. You do need to watch it doesn't climb the blade on you which means applying pressure pretty close to the cut line. I usually use a push shoe for that.
John Schaben
Old 04-13-2012, 08:31 PM   #13
Dremel?
Evstarr is offline   Reply With Quote
Old 04-14-2012, 06:54 AM   #14
Rewards Points: 111
Ace Hardware cuts 'em for ya when you buy 'em. If they screw up, they give you another. 25 cents per cut here. They score and snap with a stanley knife like the link above.
dwcopple is offline   Reply With Quote
Old 04-14-2012, 09:15 PM   #15
Being an electrician I've had to do this before. I have the best success using a Dremmel on low speed (15,000 rpm) using a standard or diamond cutter. You just need a steady hand.
RonS1985 is offline   Reply With Quote
Recessed light covers nicksteel Electrical 16 02-02-2014 01:49 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
album covers "tiled" on a concrete floor? is it possible? brian williams Flooring 3 06-08-2009 09:43 AM
Magazine covers as wallpaper-HELP memo General DIY Discussions 4 10-06-2008 08:07 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
