Cutting A Downspout - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-03-2006, 01:33 AM   #1
Cutting a Downspout
Does anyone know of a good way to cut a gutter downspout?
I have tried both a hacksaw and a pair of aviation snips. Niether one
worked that well.
croast is offline   Reply With Quote
Old 09-03-2006, 06:54 AM   #2
General Contractor
joasis's Avatar
If you are talking about cutting it to length, you may try an old blade reversed in a circular saw and carefully cut the tube, well supported, and with the saw depth only slightly deeper then needed for one side. Turn and repeat on all four sides. We keep extra blades for miter saws just for stuff like this, but remember, it takes a steady hand and ear protection.
joasis is offline   Reply With Quote
Old 09-03-2006, 06:58 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
I use a recip saw (sawsall) with a metal-cutting blade
slickshift is offline   Reply With Quote
Old 09-04-2006, 08:39 PM   #4
The Flying Toolbox
handypilot's Avatar
I'm assuming the downspouts are either aluminum or vinyl...in this case you can use a power miter saw with a carbide blade. It makes a very clean cut! Make sure to wear gloves and safety goggles, because lots of tiny metal/vinyl pieces will be flying!
For aluminum, you can also use angle grinder with a metal cut-off wheel, or a rotory tool such as a Dremel (but Dremel cut-off wheels are expensive). However, using a plain hacksaw, while cutting each side at a time, will give you a cleaner cut.
Here's a good article if your installing downspouts:
Installing Gutters and Downspouts
handypilot is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
cutting glass victor General DIY Discussions 2 08-07-2007 12:51 AM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 08:14 AM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 09:13 PM
Kitchen Sink/Counter cutting help? Lambo Plumbing 7 06-08-2006 08:31 AM
