Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-22-2012, 01:05 PM   #1
Cutting a Downspout
What is the easiest way to cut a downspout which is installed and too close to the ground?
levylh is offline   Reply With Quote
Old 03-22-2012, 01:52 PM   #2
Cutting a Downspout
Use a hacksaw.
Old 03-22-2012, 03:35 PM   #3
A "Handy Husband"
rjniles's Avatar
Cutting a Downspout
The problem with cutting it off at the bottom is you remove the crimped end and will have a problem reinstalling the elbow. Take the down spout off the house and cut off the top. Easies way to cut is a fine tooth blade in a chop saw. (I assume we are talking aluminum gutters.)
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-22-2012, 06:14 PM   #4
Moderator
kwikfishron's Avatar
Cutting a Downspout
You can make your own crimped edge with needle nosed pliers. You grab the edge of the downspout and twist. If you do that a dozen or so times around the perimeter of the cut downspout then you’ll end up with a male end that will work and look clean.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (03-22-2012)
Old 03-22-2012, 09:49 PM   #5
Cutting a Downspout
if it were me. i would use an angle grinder with a cut off wheel on it. and go slow, though it will not take much time.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Water Overflow from Downspout Drain Nospammer Building & Construction 1 10-04-2011 05:18 PM
Downspout over lower roof smcclana Roofing 5 10-08-2010 01:20 AM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting a Downspout croast General Discussion 3 09-04-2006 08:39 PM
