-   -   Cutting a Downspout (http://www.diychatroom.com/f2/cutting-downspout-137865/)
levylh 03-22-2012 12:05 PM
Cutting a Downspout
What is the easiest way to cut a downspout which is installed and too close to the ground?
md2lgyk 03-22-2012 12:52 PM
Use a hacksaw.
rjniles 03-22-2012 02:35 PM
The problem with cutting it off at the bottom is you remove the crimped end and will have a problem reinstalling the elbow. Take the down spout off the house and cut off the top. Easies way to cut is a fine tooth blade in a chop saw. (I assume we are talking aluminum gutters.)
kwikfishron 03-22-2012 05:14 PM
199 Attachment(s)
You can make your own crimped edge with needle nosed pliers. You grab the edge of the downspout and twist. If you do that a dozen or so times around the perimeter of the cut downspout then you’ll end up with a male end that will work and look clean. :yes:
Fix'n it 03-22-2012 08:49 PM
if it were me. i would use an angle grinder with a cut off wheel on it. and go slow, though it will not take much time.
