Cutting Board Counter Top Seal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 09:22 AM   #1
Cutting board counter top seal
I put two surface island with a butcher block counter top and granite. Any ideas on how to seal the seams where the granite meets the end-grain wood countertop? I know its needs to be flexible bc of the expansion/contraction of the wood but the debate is: Silicone? Nothing just template the granite to go right up next to it.
Nothing is installed yet except of the cabinets.
See image below
pgnadi is offline   Reply With Quote
Old 03-24-2011, 07:23 AM   #2
I hesitate recommending any chemical caulk since this is a food prep area. Is the wood removable?? If yes, I wouuld leave it uncaulked and remove is at least once a week and clean around/under with bleach. The wood can be sealed with mineral oil, which is safe for food prep.
Old 03-24-2011, 09:27 AM   #3
Rewards Points: 5,336
I'd eliminate the integrated chopping block. Pulling one out of a cabinet is much simple and healthier.
Ron
Old 03-24-2011, 11:52 AM   #4
We've already decided on embedding the cutting board into the island and its just a matter of how to seal that seam. I think we will just use a clear silicone. Seems to be flexible and is really only for avoiding crumbs and what not entering in the seam.
They will be attached to the cabinets below and will be flush against each other so i dont see it being much of an issue.
Old 03-24-2011, 11:55 AM   #5
Just Bill
The board is 4 feet long so its large enough that you dont have to cut on the siliconed part. Not its not removable.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 11:50 PM
Cutting Counter Top sleepysmurf Carpentry 3 08-14-2010 12:16 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Cutting Board for Ductwork Build Building & Construction 21 06-22-2009 10:11 AM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 10:33 PM
