Cutting Bead Board - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-08-2008, 12:50 PM   #1
cutting bead board
Is there a trick to cutting bead board? I'm afraid just ripping it will leave jagged edges and such. maybe scoring it with a utility knife? Thanks
scatterbrain is offline   Reply With Quote
Old 01-08-2008, 06:27 PM   #2
(the original)
Rewards Points: 756
What blade are you using? I've never had any problem using a good plywood/melamine blade.
ratherbefishin' is offline   Reply With Quote
Old 01-08-2008, 06:58 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Always rip on a table saw with the finished side up.For rips with a circular saw,finished side down.
oldfrt is offline   Reply With Quote
Old 01-09-2008, 09:13 AM   #4
Thanks, guys. I was using a jig saw with a fine tooth blade. I duct taped where I wanted to cut and it did a fine job. No rips or splinters. thanks again for the replies.
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 04:42 PM
Removing water stains bead board Mikon Painting 5 10-08-2007 05:57 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
