Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-06-2012, 08:14 PM   #1
cutting bar rail angles
I am installing a chicago bar rail and I am having trouble getting my 45 degree
angles to meet. I am told to use a spoiler rail when I make the cut. What size spoiler should I use to cut a 5" rail so the corners will line up?
cmack12
cmack12 is offline   Reply With Quote
Old 12-06-2012, 09:14 PM   #2
Not clear on what your trying to do.
Any bar rails I've seen just use a slip on fitting to make a corner.
http://www.wagnercompanies.com/Foot_...omponents.aspx
Got a picture?
Old 12-06-2012, 09:20 PM   #3
Super Moderator
I'm confused ,too----post a link to something similar---Are you talking about a brass foot rail? Wood bar nosing---or a speed rail for the back of the bar--??If this is it---use a 2x4 or other wood to perch the piece on--then cut it---figuring your miter lengths can be tricky as the 'corner ' is actually inside that cut out ---
Old 12-10-2012, 10:22 AM   #4
My question was how to accurately cut the corner angles of the bar rail for a perfect match up at 90 degrees
My rail has 2 lips .. My question is how high do I make the spoiler bar when cutting a 45 on a miter saw I will try to attach a picture
Old 12-10-2012, 11:13 AM   #5
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Basically, ya gotta do the miter cut, with the rail in/ at the angle it's gonna live at, like in yer picture, Not flat on the saw table...
Kinda like doin' crown moldin', only upside-down...
The Following User Says Thank You to Bondo For This Useful Post:
hand drive (12-10-2012)
Old 12-10-2012, 01:13 PM   #6
AHH, SPANS!!!
as bondo mentioned do it like that. use a level and find the difference in the height top to bottom and use a shim of sorts to hold the piece at the saw on that angle while cutting it. it looks like right behind the bottom lip there at the underside of the piece is about an 1 1/2" flat spot and the next angle along the underside, I'd plan to use that flat spot and the angle to set the (cut shim) on while cutting...
hand drive is offline   Reply With Quote
Old 12-11-2012, 11:04 PM   #7
Thanks I"ll give it a try
Old 12-12-2012, 02:19 AM   #8
Try it and then post a pic here; I want to see what exactly you have done.
henrylarry6 is offline   Reply With Quote
cutting mouldings that are not right angles it99 Carpentry 7 05-04-2012 01:34 PM
Cutting slight diagonal angles on cheapo wet saw jdbs3 Flooring 4 11-08-2011 11:50 AM
cutting trim to fit angles Davidb6 Carpentry 5 07-09-2009 02:29 PM
Cutting curved stair rail fittings beerdog Carpentry 2 05-11-2009 07:21 AM
Angles for cutting crown mouldings sjrhome Carpentry 14 04-13-2007 08:14 AM
