Cut Trunks Into Slices? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-15-2014, 12:38 PM   #1
Rewards Points: 182
Cut trunks into slices?
I have 10 trunks I'd like to cut into 1 to 2 inch slices (or cookies). They're all about 11 to 15 inches thick and up to 18 inches high. How can I cut them?
P.S. - they're all from a cherry tree cut down almost two years ago so they're definitely dry
anuvanoob is online now   Reply With Quote
Old 03-15-2014, 01:26 PM   #2
Rewards Points: 1,686
Two man cross cut saw.
Old 03-15-2014, 01:30 PM   #3
Rewards Points: 182
Yikes! Anything easier? For one person?
Old 03-15-2014, 01:50 PM   #4
Civil Engineer
Rewards Points: 4,856
You can cut with a chainsaw, but trunks can be very tough on the blade. They often have embedded metal or other debris, and it is very difficult to get an even cut of that thickness. Most mills are not going to want to deal with this type of cutting for the same reason.
Old 03-15-2014, 04:27 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,.... Cuttin' 'em with a chainsaw would be easy enough,...
Holdin' 'em, so's ya could chainsaw 'em might be somewhere 'tween tricky, 'n dangerous though,...
I wouldn't cut 'em any thinner than 2" either,...
They'll split, 'n fall apart,...
'n as far as gettin' a straight cut,... Practice makes perfect,...
I burn well over 30 cords a year, 'n have framed buildin's with a chainsaw,...
The Following 3 Users Say Thank You to Bondo For This Useful Post:
JustinK (03-16-2014), kwikfishron (03-15-2014), oh'mike (03-15-2014)
Old 03-15-2014, 09:50 PM   #6
Rewards Points: 2,418
Maybe the largest bowsaw that you can find.
ED
de-nagorg is online now   Reply With Quote
Old 03-15-2014, 10:00 PM   #7
Rewards Points: 3,130
A big bandsaw?
Old 03-16-2014, 06:51 AM   #8
previous images next images Enlarge Image
<IMG class=product-thumbnail alt="Valley 36" 915mm="" bow="" saw?=""> Valley 36"/915mm BOW SAW
Item # SPM7081936407 Model # EV_0396720
At sears.com A 36 inch for 23.99
Old 03-16-2014, 09:36 AM   #9
Rewards Points: 352
It easy enough to do with a chain saw. Make them an inch or two thicker than you want it to be when finished. This will allow you to smooth it out with a router sled or what ever method you choose. Maybe go three inches thicker if you plan to dish them out for a tray.
RegeSullivan is offline   Reply With Quote
Old 03-16-2014, 02:32 PM   #10
Rewards Points: 182
Will any of these do the job? That big one is 18" long and has I guess what's considered big teeth. Not sure what type of saw it is though (someone left it behind in my house).
Old 03-16-2014, 02:36 PM   #11
I see a bowsaw, a backsaw, and a blade for a reciprocating saw. All great gifts to have left behind by the previous owner/ tenant.
ED
Old 03-16-2014, 03:06 PM   #12
One man cross cuts are available also.
To hold the trunks for sawing, weld a lag screw to the pick up truck receiver hitch. Bore an appropriate diameter hole in the trunk about 3" deep and screw the trunk on the lag.
Cancel the gym membership and after making about 70 cuts you can get your saw cost money back entering and winning arm wrestling contest.
Old 03-16-2014, 03:47 PM   #13
Rewards Points: 6,652
Find someone with a portable lumber saw. Or see if there is a local lumber yard that would do this work for you.
Old 03-16-2014, 06:44 PM   #14
joed's Avatar
Rewards Points: 13,344
Chain saw works fine for this. I have done it. Just need some one else holding the log. If you want screw a 2x4 to the log as a handle. just don't saw the screw.
Old 03-16-2014, 07:05 PM   #15
Having a jig for keeping the cuts straight, also works joed. They make bars for chainsaws, that you can use to hold the end in a jig, just like a Chop saw.
Slices romex toastandjam Electrical 4 11-06-2012 05:36 PM
What to do about tree with multiple trunks -Q- Landscaping & Lawn Care 1 04-28-2009 04:36 AM
